Hello.
I have 883 with shims of 10 mm on driver side and 5 mm on passenger side on the strut so i get 10-20 mm higher in front. I have considering change to 884 instead. I know that the 884 spring is a bit longer than 883, but is it stiffer than 883? I know that 883 is calculated for 50 kilo more weight in front, and 884 is for 100 kilo (25 mm in front). I have a 9000 lbs winch only, but that is on a 2" reciever, so when I dont use it, I have it in the lugage room.
Will it be the same stiffness with 884 without the shims like I have today?
