maxxis bighorn 275/70/17
  • maxxis bighorn 275/70/17
    has anyone had these tyres ?
    ive got a two inch lift and am wondering if anyone has had any problems with body or strut rubbing ? cheers
    Marty gx Prado 05 manual diesel, a/c , abs
    Hi Ell,
    Are you suffering that problem would be nice to know if we could all get those boots on without any trouble!
    Regards
    Geoff
      no, havnt bought them yet but seriously considering . have you heard of any troubles geoff ?
      cheers, marty
          Plenty of posts on this already - you will rub your UCA, in some cases with 265/70R17 you will rub at full lock..... so if you want to run this size tyre you would need +10 offset rim in a 17x8 (dymanic make these). I'd go a 285/70R17, but you'd have to make sure you have enough suspension lift to accomodate - need at least 3".
          Double_d
          [b]2006 GXL Prado 1GR-FE [/b]- ARB Lockers & Bar, Tigerz11 Winch, snorkle, Custom Bash Gaurd & Steps, AJ4x4 Rear Bar, Spotties, UHF, Dual batt, 33" KM2s, Custom drawers, Ext Icon Coilovers, 4" SRC Shockies, Dobinson 4" Springs, Diff drop, Light Racing UCA's, Ext SS brake lines, Driveshaft spacer, Superior trailing arms, Nitro 4.56 diff gears, DBA Slotted brakes, TRD Supercharger, Bullet Ultimate Exhaust, XEDE Dual map Processor
            thanks double_d , its hard to get the exact answer your lookin for , thats exactly what i wanted to hear . cheers
              After doing some research on the same issue, i ended up getting the Bighorn's 762 (there is a new model 764) - mainly due to budget reasons. I only have a 2" lift and the toyota rims - No issues nor rubbing at all.
                What size tyre have you bought? 275/70/17 presumably given the thread title.
                  I had 275/70-17's on my 120 Prado, ran it like that without lift for a few weeks and did rub a little when the wheel tucked up into the guard . . . put 2" lift in and not a problem in the world.
                  These are a great tyre for the price . . . I'm pricing the bighorns for my second 120 Prado, looks like $330 to $340 each is the going price in WA.
                  [i][b]Style is nothing, image is everything[/b][/i]
                  [url]http://vimeo.com/4272281[/url]
