265/70R17 Coopers ST / BFG AT etc
  • 265/70R17 Coopers ST / BFG AT etc
    Going to upgrade the grandtreks. managed a $100 trade in with 12k on each tyre. Thinking Cooper ST's pr BFG AT's.
    Has anyone with first hand experience able to comment on the above tyres ie
    Due to increased size, do they affect performance..power,towing, hills etc?
    Do they rub guards..stock suspension?
    Do they fit on rear door? Hard wheel cover?
    Do they muck up alignments and balance making the prado drive like a truck?
    Will be fitted to a D4D auto.
    07 GXL D4D Auto
    265/70/17 Cooper St, ARB Dual Battery, IP900XS Spots (crap), Black Widow Draws, Cargo Barrier,Billy Lovell combo, polyairs, reverse camera,
    Gday
    I have run a previous 120 on Cooper ATR in stock size
    My new D4D is running ST;s in 70 profile
    The ATRs were excellent on road and moderately good off road. Overall i was very happy with performance and longevity
    The STs are noisier, but not annoyingly so, it is acceptable
    On road behaviour is fine with no particular issues
    Off road they are a quantum improvement and i am very happy with them
    I havent really noticed any affect in vehicle power or performance
    They fit with no issues or rubbing, but i do have a lift in the car, so cant comment on standard suspension, but in looking at the wheel arches and available space on stock suspension i wouldnt envisage any problems
    The spare wil require the removal of the black plastic bit and some spacers to make sure the tyre doesnt contact the body work
    Any hardcover will become useless with the larger tyre, it wont fit
    I have no experience with BFGs on a Prado, but based on experience with another vehicle, I have a very poor opinion of them in terms of sidewall strength
    hope that helps
    Glen
      Glen,
      Do you have and auto or Manual D4D?
      I've got a second set of wheels that I'm going to fit with 265/70/17.
      I opted for a second set of wheels to allow me to get more agressive tyres for just off road and also because I'm concerned how the increase in rolling diameter will effect the auto shift points. Which might become annoying for city driving.
      Leachy
      EX-Prado Owner
        Gday Leachy,
        Mines an auto
        If I had the larger tyres on the 4 speed auto, I think it would have been absolutely awful, with the gearbox "hunting" to find a happy place
        The 5 speed is just as smooth as silk and very happy sitting behind the D4D, it can be as lazy as the motor at low revs, or as responsive as you would like with a bit of stick
          Thanks for the info glen.
          Has anyone considered the 245/70r17 cooper ST. same height just a little bit narrower width wise (0.78''), also 10 ply
          07 GXL D4D Auto
            Hi
            Ive got cooper st on my Hilux.I find them a bit on the noisy side but nothing two notches on the radio dont fix.Il most likely go the same way with the prado when it arrives.
            never had a flat tyre when we go bush,but have had two flats on the black top
            Regards Rob
            Waiting - Silver Ash,Option pack 1,GXL Prado
            - 6 speed manual
            - D4D Turbo diesel
            - Bilstein/Lovells suspension
            - Deluxe ARB Winch Bar with fog lights
            - Warn 9000 LB winch
            - Digital in dash Turbo Timer
            - Safari Snorkel
            - Black Widow storage drawers
            - H/D Tow Bar
              i have been looking at this extensivly (and have a thread you could have referenced not far from the top in this section)
              i have decided to go 694's in 275/65's as that is the most i can go legally in QLD.
              if the new model comes out and confirmed with 275/65's for the aussie spec one, i will consider going to 265/70's..
              2004 GXL V6 5 speed auto. Cooper STTs, 40mm Lift, Scanguage II, Flyer batterybox, GME3400 UHF, Engel 40L, Safari Snorkel, IPF Xeon Headlight upgrade, Milford Cargo Barrier.
              [img]http://users.on.net/matthewv/4wd/prado.jpg[/img]
                That's a very interesting question. I was looking at the specs on these tyres myself recently.
                I'd also be interested to hear if anyone is running them.
                Drew.
                  I had every intention of running the 245/70's...until I rang Toyota :roll:
                  They expressed a view that both 265/70 and 245/70 were out of spec and would both cause them to deny warranty if the tyres were a contributing factor
                  Sometimes you cant win even when you try hard to do the right thing, I explained at length that the rolling diameter was the same, load rating was in spec...even that that the GX ran 225's...they just dont want to know, there way or the highway is the answer you get back
                  So, in the end, went with 265's to take advantage of the size
                    decided to go the 265/70r17 cooper st. will report in due course
                    in regards to the toyota warranty issue.....Just to be sure, I'm gunna do a wheel swap with a mate who has stock grandtreks. Its only 1 day every 6 odd months that i have to see the service department.
                    I highly doubt that the service techs will have the mental capacity to even notice the bigger coopers...but i'll still swap just in case.
                    07 GXL D4D Auto
                      Originally posted by Pradogxlv6
                      Dealers make so much money, riding on the back of a strong brand and market share, they don't want to know about anything 'outside the box' of standard specs..
                      Yes, it is pathetic, but the truth... :cry:
                      Mate, brace yourself for the bleeding hearts claiming we don't give the poor old dealers a fair go... boo bloody hoo...
                        Tee hee. :lol: Welcome back gman. You missed a cracker of a trip up the mountains last weekend. Looks like you've been having fun yourself. Where's the trip report mate? :-)
                        Drew.
                          I notice the comment on the old 4 speed with the bigger diameter tyres, I have the old 4 speed and the 265,70,17s, I didnt notice any changes to shift patterns etc when I changed up in size, certainly doesnt hunt for gears or anything like that, Also have never had any comments from Toyota service, I doubt they would even notice or know the difference !
                          Just to add my few cents worth, the ST are a tough tyre, I run them on my work truck and they cop a hard time loaded, day in day out in all sorts of rock and rough terrain and have survived admirably with so far not a single flat( 60K)
                            Hi speedcomm,
                            That was probly my comment regarding the 4 speed. It was just a thought without any sound fact to back it up. The 4 speed in my old Prado had some interesting habits when towing and I always felt it wasnt madly happy under load of towing, the extension to that was that larger tyres wouldnt have helped
                            At the end of the day, the 4 spped and V6 combo was very good, now the 5 speed and D4D is betterer in my humble opinion 8)
                            Glen
                              Let me know how they go when you get them.. I am considering keeping my 275'a off my Patrol when I sell / trade in (which ever comes first). My VX is due for delivery 31/10 so time is running out to decide!! Still got the original Duellers from the Patrol ready to slot back on if need be.
                              Phil
