purchased a set of aftermarket alloys for me truck (copy of gxl wheels) and found the standard wheel spanner will not fit inside the slot to undo nut, normal 19mm socket fits ok. just wondering if anyone else had the same problem
aftermarket wheels
And while you are buying your 19mm socket make sure it can handle heaps of torsion they are coloured black, this enables you to undo the wheel nuts that some of our less educated tyre/ servicing companies that don't use a torque wrench to check the correct tension of wheel nuts on alloy wheels. :x :x :x07 Upgrade GXL D4D, Manual, Dune,Sov Bar, BFG's, SG11, Redark dual Batts, Extensive Aux wiring, Stebel, LED stop tails, IPF HID's (my mod), 240V Inv, ARB Comp, GME UHF,TPMS, Safari snorkel, GPS,Hilux washers, 40l Engel in 30% pas pos,homemade A/C cond protection plate, polyairs.
