Originally posted by Ghost
View Post
Larger tyres for prado
As long as it doesn't have ESC.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
I have today received - in writing - confirmation from the RMS Technical team that VSI6 'Light Vehicle Modifications' covers all vehicles up to 4.5t gvm, so our 4wds are covered by it. As such, tyre diameter increases of 7% are allowed - going on 265/65R17 diameter of 776mm, we can fit tyres up to 830mm diameter in NSW, meaning 265/70R17 (803mm) are legal. There is also no mention in VSI6 about combined limits re tyres and suspension changes (the only mention re suspension is that vehicle ride height cannot be altered by more than 1/3 of the manufacturers suspension travel in the direction of the ride height change), nor any mention that the changes are not allowed on vehicles with ESC. Just in time too, as I'm due for new rubber soon, and 275/65R17 isn't well supported in aggressive tread tyres.2004 Grande V6 4.0, ARB colour coded bar, Magnum 9k winch, dual battery, HD King springs/Bilstein F4-BE5-A712-MO (front), Airbag Man extended airbags/OME Sport 150R shocks (rear), OziOffroad diff drop, BFG KM2s, Hella 225s, ARB CKMA12 compressor, Rhino-Rack HD bars x3/alloy tray, Sunseeker II awning, Prodigy, TX3340, cargo barrier, 50L water tank with 12v pump, rear storage system, Waeco 60L with slide, rear door table, rear camp light.
Yep, that's the link to the VSI6 document.
The 'writing' is email, not a letter - essentially the last email in the trail reads:
"Steve
A light vehicle is anything up to 4.5GVM, yes yours is a light vehicle.
Jonathan
Technical Enquiries"2004 Grande V6 4.0, ARB colour coded bar, Magnum 9k winch, dual battery, HD King springs/Bilstein F4-BE5-A712-MO (front), Airbag Man extended airbags/OME Sport 150R shocks (rear), OziOffroad diff drop, BFG KM2s, Hella 225s, ARB CKMA12 compressor, Rhino-Rack HD bars x3/alloy tray, Sunseeker II awning, Prodigy, TX3340, cargo barrier, 50L water tank with 12v pump, rear storage system, Waeco 60L with slide, rear door table, rear camp light.
You should have no problems at all with that. Put that size on my first Prado pre lift without issue.Originally posted by crozmac View PostSo just to be sure a '07 120series D4D that is stock (suspension and height etc) along with standard front bumper will allow me to fit 265/70R17 with no rubbing or any other issues?
Not interested in regulations etc as I live in NZ just want to know if the will fit fine.
Isn't 265/70/R17 the size for Grande Tyres?Originally posted by Way2go View PostI have today received - in writing - confirmation from the RMS Technical team that VSI6 'Light Vehicle Modifications' covers all vehicles up to 4.5t gvm, so our 4wds are covered by it. As such, tyre diameter increases of 7% are allowed - going on 265/65R17 diameter of 776mm, we can fit tyres up to 830mm diameter in NSW, meaning 265/70R17 (803mm) are legal. There is also no mention in VSI6 about combined limits re tyres and suspension changes (the only mention re suspension is that vehicle ride height cannot be altered by more than 1/3 of the manufacturers suspension travel in the direction of the ride height change), nor any mention that the changes are not allowed on vehicles with ESC. Just in time too, as I'm due for new rubber soon, and 275/65R17 isn't well supported in aggressive tread tyres.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
No, standard Grande tyres are 265/65/17, same as the GXL.Originally posted by MidLifeCrisis View PostIsn't 265/70/R17 the size for Grande Tyres?
That's surprising, I had to space mine out a bit,which is not hard to do.Originally posted by ScottT View Post
Also fits the spare wheel carrier without adjustment
Cheers, Scott
From memory mine fouled on the rear windscreen wiper. It was a bit of a panic at the time as I think it was only a day or 2 before we headed to the Kimberly.
That surprised me too. When I had the 265/70s fitted at delivery the cowboys jammed the rim on the bracket with some longer bolts that didn't work at all. Everything was out of alignment. I ended up welding on the spacers and also completly discarding the useless plastic trim that sits behind the wheel. It only serves to trap stones against the paintwork.Originally posted by AJ120 View PostThat's surprising, I had to space mine out a bit,which is not hard to do.
Cheers AndrewDave
