NSW engineering cert for 265 70 17's
    Ok I had the prado looked over by the RMS certifier, and all was good except for the speedo being out. He said about 5% at 100km/h. Unfortunatly the RMS does not allow for the vehicle to traveling faster then the speedo is reading. So I started looking around for a auto electrician that could do the re calibration. And I found one in Canberra. Will cost $250 to fit the product, like the yellr box. Then ill have to pay the certifier about $300.
    At least I now have it sorted
    Troy
    2005 Toyota Prado Grande 3.0 TD - ARB Deluxe winch bar, Avenger 9500lb winch - nylon rope, Safari Snorkel, DP Diesel Chip, Lightforce HID 240's 50w, Oricom UHF, Bushranger Mud Tamer mats, Toyota Genuine Tow Bar, Toyota Genuine bonnet protector and headlight protectors, ARB Roof top tent and awning, ARB dual battery system with Red ARC and Optima deep cycle battery, Max Trax, ARB Compressor and Rear Air Locker, Waeco 50L fridge/freezer.
      Nice work Troy, keep us posted on which speedo calibration solution your sparky comes up with, especially if yellr box isn't compatible with ABS equipped vehicles.
        I got an email from Yellow Box speedo correction today. They are currently researching their speedo calibrator for the Prado with ABS and they say it is compatible. Hopefully their solution will include a plug n play harness. I'll keep you posted on what they come up with.
          Sounds good Peter. Wondering.. If a engineer deems the larger tyres 'legal', does that mean a insurance mob will cover ya ? I remember hitting NRMA up about it ages ago, they told me I can do whatever I want, as long as t deemed 'legal' by the RTA.
          If so, once my tyres wear out, 70 series rubber for me..
          [CENTER][B][U]Matt
          [/CENTER]
          [SIZE=2]
          [/SIZE][CENTER][SIZE=2]
          [/SIZE][/CENTER]
            I rung NRMA last Friday, they say NRMA insurance will cover provided it is deemed legal by RTA NSW.
            RTA have confimed via email that larger 265x70x17 tyres requires certication and they provided a list of certfiers.
            Rung few certifiers and some seemed not sure about what their work will involve and they had no idea how much it was going to cost me. Found a certifier in Riverwood $300+GST.
            Troy - please keep posted when you get the calibration and certification.
            I would probably calibrate speedo using this thread:
            http://www.pradopoint.com/showthread...=grande+speedo
            The speedohealer gadget is also availble on ebay for around $130.
              Update, well took the prado in and well they plugged it all in and took it for a drive and well after 100m or so dash lights came on and then loss of power as the transmission went into limp mode. :-( tried to different brands of speedo calibrator and had the same result. The auto electrician contacted the company in melbourne who is trying to work on a solution. Apperently they have done it on 2005 models and earlier before with out any issues, although they said after 2006 you cant do it cause the wiring is different and you cant splice into it. Although from previous posts i believe those vehicles are all ready running under so would be running accurate with the 70 profile tyres and would there for not need a re calibration. Apperently my grande being a late 2005 is a high breed between the two hence the issues. Fingers crossed they find a solution. Ill keep you posted
              Troy
                That's a bugger. Was this using a "Speedo Healer" or a "Yellow Box" device? Were all the connections soldered or just crimped?
                  What happens when I drive my legal in VIC with 265/70/17 tyres across the border into NSW?
                  http://www.vicroads.vic.gov.au/NR/rd...orvehicles.pdf
                    If you are legal in the state registered then you are legal Australia wide. I may not stop a copper pulling you up but you are legal.
                    2012 GX Prado 150 D4D Glacier White Auto with colour coded Rear Kaymar Tow bar Step, TJM T13 Bull bar, Safari snorkel, 100A Lifeline Battery, TJM battery tray, Redarc DC-DC 40A charger, 8" in dash GPS, Speedy Avalanche Wheels, Coopers 265/65 r17 AT3, AMTS Bash plates, TJM Side Steps, Ultimate Suspension 2" lift, Premier Winch.
                      Peter,
                      It was neithier of them one was the VDO equivelent and another brand which is also made locally in sydney. In regards to your other questions I am not sure. sorry.
                      Troy
                        Here's something to add to the discussion. If my 150 will read spot on with 70 series tyres, do I just book a engineering to access the car and plate it if it passes ? Then tell NRMA it's legal and add the larger tyres to the policy ?
                        [CENTER][B][U]Matt
                        [/CENTER]
                        [SIZE=2]
                        [/SIZE][/CENTER]
                          Yes pad pad pad
                          • #28
                            You don't even need to tell them it's legal - your insurance paperwork will show the onus is on you to ensure it's legal, all the insurer is interested in is knowing what the options/accessories/mods are that need to be covered in terms of value.
                            Even if the speedo reads accurately on 70 series tyres, I think you'll find the engineer wants to sting you an extra $250 + GST (or so) for a GPS speedo check. When I was looking into this, I couldn't find an engineer who would certify the larger tyres without doing a speedo check......
                            • #29
                              True story at least you dont have to worry about recalibration.
                              • #30
                                I have just installed Yellow Box V5 with splice wiring (solder connection) on my Grande 120, tested and calibrated speedometer for bigger tyres. I will post my full installation information hopefully in few days time.
                                The Yellow Box V5 works fine and I am very happy and also particularly thankful to Jenny at Yellow Box who has been excellent in finding the correct solution. For about $79.95USD, or about $76.40AUD, it is a very good value. Thier website and contact details:
                                www.YellR.com
                                [email protected]
                                AB
