Brand New 17" 120 Alloys.
  • Brand New 17" 120 Alloys.
    Hi All,
    If anyone is looking for some 120 17 x 7.5" GXL/VX/Grande alloys, I am able to sauce them relatively cheaply.
    You may only need one for an extra spare, a new one to replace the one your mrs scraped, or you may want 5 to replace the stockers on a GX. Whatever your need, I am able to get them for $210 a wheel.
    They are brand spankers and still in boxes with nuts, valve stems, and centre caps.
    Cheers.
    OE or aftermarket?
    Tomato or BBQ sauce?
      Aftermarket.
      Are identical as a brand new vehicle wheel. I have 1 of these wheels in my 6 wheel rotation and to be honest, I wouldn't know which one it was now.
      Cheers.
        17" Prado alloy
        Hi There D4DPrado
        Are you still able to source the alloy wheels? I am looking for a second spare. I have spoken to a supplier in Melb who says he can supply aftermarket replicas but they need to be used with the specific nuts which are not the same as the OEM ones. Is this the case with your wheels?
        Thanks for your help.
        2007 Prado GXL D4D
          I am in the same boat as your Melbourne guy. :roll:
          These wheels that I have use to be made with the same nut base as the OE which is a flat base on the nut. However, these are now made with a tapered nut base.
          Obviously it would just mean that you would have to carry a set of tapered nuts to use that wheel if necessary.
          Cheers.
            Wouldn't mind a set of five to replace the originals on my GX . What do you recon the the freight to Tas. would be ?
            What is their origin ? Speedy Wheels make a replica in Aus and they sell for around $220 if you look around they don't come with the Toyota center caps however .
              You could probably get them machined to accept the OE nuts.
              2008 GXL M6 D4D, Silver
              Build Up---> [url]http://www.pradopoint.com/viewtopic.php?t=2315[/url]
              [b]{[/b]ATS Ridepro/Bilstein Lift[b]}[/b] [b]{[/b]Dual Batteries with RanOx Battery Booster[b]}[/b] [b]{[/b]600w Projecta 240v Inverter[b]}[/b] [b]{[/b]Dunlop AT3's / MT MTZ's on Speedy Grande Rims[b]}[/b] [b]{[/b]ARB Deluxe Winch Bar[b]}[/b] [b]{[/b]IPF900XS Spotties - Converted to 50w 4300k HID[b]}[/b] [b]{[/b]35w H4-3 4300k HID Hi-Lo Conversion[b]}[/b] [b]{[/b]ARB Underbonnet Compressor[b]}[/b] [b]{[/b]GME TX3440[b]}[/b] [b]{[/b]T-Max 10,000lb winch[b]}[/b] [b]{[/b]Safari Snorkel[b]}[/b] [b]{[/b]Milford Cargo Barrier[b]}[/b] [b]{[/b]Rhino HD Roofies & AT1410 Roof Tray[b]}[/b] [b]{[/b]60L Waeco[b]}[/b]
              [img]http://www.gifs.net/Animation11/Transportation/Cars/4_wheel_drive.gif[/img]
                Honestly, I could not tell you the freight charge to Tassie. May pay to make a call to your local national courier depot. See how you go Bruce. Cheers.
                  Hi Big Bruce,
                  I'm actually looking to get some steel wheels to put on a camper, and as an off road set for the Prado (when it comes). Are your steelies 17 x 7.5 ?
                  If you were wanting to sell them I could be interested. PM me if you like.
                  Cheers, Bes.
                  Currently driving 100 series V8 Landcruiser - Will be changing to a D4D Prado in 2008 - ordering soon !
                    I think you are asking for trouble with insurance, warranty, and strength issues once you machine peices off a wheel. Especially around the hub and nuts of a wheel.
                      NO Bes I have a 2003 GX so they are 17x6 , with Cooper AT's with about 20 k on them .
                        Hi D4DPRADO ,
                        Could you supply me with the box size for a wheel and its weight , and I will talk to my usual freight agent .
                          About 450mm x 450mm x 190mm and around 8-9kgs.
                          Cheers. :wink:
                            hey big bruce i got a set of replica gxl wheels for $200 a pop with toyota centre caps, best 1k i ever spent as it got rid of the poxy gx wheels, the brand is lensco, its on the borderline of needing flares but it looks good
                              Hi Big Bruce, .... OK .... Thanks anyway.
                              Cheers, Bes.
