I have told a few people that I would do a bit of a how to on removing and replacing tyres from an alloy rim. As I had a puncture to repair I’ll add that as well.
The skills required to do this are minimal but its best you try at home first if you have never done this before, in the bush isn’t the best place to learn. Its also best in the bush to do this on a tarp to keep things clean.
In this instance I am removing the tyre and repairing it and replacing the same tyre, so in order to keep the wheel balance correct I need to mark the position of the valve so I can replace the tyre in exactly the same rotation. If you have nothing to mark it with you can just make a note of any mark on the tyre the valve lines up with, in this case the 5 in the 265, also I know I have the white lettering “in” so I can get it back on the right way round.
I also needed to locate the puncture, a combination of listening and some soapy water in a spray bottle found it very easily. The soapy water (dish detergent) will also come in very handy down the track. I then marked it so I can find it after the tyre is removed.
If you look closely you can see the bubbles from the leak.
After removing the valve it is time to break the bead. There are a few ways to do this but I use the bead breaker I designed and made that fits on the OE Toyota jack. Have a look here for more details on that http://www.pradopoint.com/showthread...e-Bead-Breaker
And here is a video of me breaking a bead at the 2012 GTG
