2006 prado max tyre size without lift
    Just put in a 2" lift then put 265/70/17 BFG km2 on. Totally transformed it.
      Originally posted by v6 prado View Post
      Thanks ####, so I'm assuming there is no rubbing and still plenty of clearance when the suspension is compacted??
      Clearance, but not plenty. It depends on brand of tyre, they all vary.
      Also depends on wheel alignment, castor adjustment.
      As you can see a few of the guys had no issue, it looks like piggy is the only one with issues, piggy what tyres?
      I have many customers running 70's on standard suspension, no probs.
      Better with a lift, this one is stock, except for 40mm lift & 265/70-17 mtz's which it had before the lift.
      Anth120playdo
      Banned
        Yep, that's all you need.
          265/70. Seen them rubbing on lock on a number of non lifted prados.
          Also seen them rub inner sway bars on lifted.
          Mickey MTZ.
            no rubbing on my sagged 2003 with worn 265/70. Just had Cooper AT3 fitted this afternoon and no rubbing so far but only driven 5km
            Cheers, Dave
            2003 KDZ120 - Cooper AT3, Dual Batt, Scotts Rods 3"exhaust, home made shelves, Sovereign Bar, HID lights, Firestone Air Bags
              Thanks guys , so I will get the lift to be sure anyway. don't need to go overboard with bloody great Hugh tyres, more fuel and wear and tear on car.
                gday clay, i do alot of beach driving, (well i did until i brought the 120) waiting to upgrade suspension and tyres till i go to fraser is. I usually get Maxxis tyres, are those BFG'S good for sand and gravel??
                  The AT version are great in Sand and Gravel.
                    thanks andrew
