I'm looking at a box trailer in the next few months but thought it would be cool to put Prado rims on it. It seems most trailer have a 5 stud pattern. Has anyone changed that to a 6 stud 139.7 PCD? I thought running some genuine rims would look good and give the trailer more clearance.
Anyone put a 120 series hub on a box trailer?
Wish list in order I'll get them: Sliders, 2" lift, E-locker, Winch bar with winch.Tags: None
Originally posted by BiLLz0r View PostI'm looking at a box trailer in the next few months but thought it would be cool to put Prado rims on it. It seems most trailer have a 5 stud pattern. Has anyone changed that to a 6 stud 139.7 PCD? I thought running some genuine rims would look good and give the trailer more clearance.
Yes, that's another bonus.2007 GXL V6 - ARB Bullbar with LED lights, snorkel, extractors, 2 1/4" dual exhaust, K&N filter, dimpled/slotted rotors, headrest dvd players, Ebay Satnav/reverse camera, GME 3100TX, Tigerz11 Side awning on custom brackets with Maxtrax mounts, 300W Invertor, ARB Underbody protection, Lightbar and STZ 265/70 tyres.
http://www.spinnythings.com.au/index...y&path=8_32_33
And this site will give you the stud pattern for all the Landcruiser/Prado wheels
http://www.wheel-size.com/size/toyota/land-cruiser/
Then you only need to ensure there is space under the guard for the Prado wheel.
The Spinnythings catalogue has quite good instructions to work out what you need.
S.155 SX with dual battery and Polyairs in the rear springs..
Any trailer parts or bearing shop should stock the hubs and bearings to fit the existing ford / holden stub axles, easy job to swap them over.
Either lifting blocks or a spring over conversion, depending on the existing trailer setup, should get you the clearance required height wise if you need more, getting the offset correct may be the hard part, may need a longer axle so the inside of the tyres don't rub as the prado rims will probably be less offset than the original trailer rims
Thanks everyone. I'll ask the trailer joint I buy it from to sort out the hubs etc.2007 GXL V6 - ARB Bullbar with LED lights, snorkel, extractors, 2 1/4" dual exhaust, K&N filter, dimpled/slotted rotors, headrest dvd players, Ebay Satnav/reverse camera, GME 3100TX, Tigerz11 Side awning on custom brackets with Maxtrax mounts, 300W Invertor, ARB Underbody protection, Lightbar and STZ 265/70 tyres.
I went to a local trailer guy in Southport today to get a quote on a 7x4 and 7x5 box trailer with higher suspension and 6 stud hubs. Not gonna happen without having a custom made trailer done or an offroad heavy duty type trailer (i.e. mega $$$$$). The 6 stud hubs, wheels and tyres just don't fit in the guards.
They normally come with a 13" wheel and the suspension under the axle. He quoted me 14" rims and the suspension over the axel. That'll raise it a couple of inches and will be high enough for my light intended use.2007 GXL V6 - ARB Bullbar with LED lights, snorkel, extractors, 2 1/4" dual exhaust, K&N filter, dimpled/slotted rotors, headrest dvd players, Ebay Satnav/reverse camera, GME 3100TX, Tigerz11 Side awning on custom brackets with Maxtrax mounts, 300W Invertor, ARB Underbody protection, Lightbar and STZ 265/70 tyres.
I built mine but there are other trailer manufacturers. Depends on your budget but I suggest giving Belco etc a call.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Originally posted by mjrandom View PostI built mine but there are other trailer manufacturers. Depends on your budget but I suggest giving Belco etc a call.2007 GXL V6 - ARB Bullbar with LED lights, snorkel, extractors, 2 1/4" dual exhaust, K&N filter, dimpled/slotted rotors, headrest dvd players, Ebay Satnav/reverse camera, GME 3100TX, Tigerz11 Side awning on custom brackets with Maxtrax mounts, 300W Invertor, ARB Underbody protection, Lightbar and STZ 265/70 tyres.
