New rims for the 120:) what size is legal ?
  • New rims for the 120:) what size is legal ?
    Hey guys,
    Need some help with understanding the NSW law on changing my rims and tyres from my 120.
    So at the moment rims and tyres are stock but have a 2 inch lift
    I have found the rims i like but not in 17inch rims they are 18 x9 . was after the equivalent of 265/70/17 so would be tyres would be 265/65/18 ??
    put all this into a online calculator and says
    "Compared to your existing wheel, this new wheel will have an inner rim which is 7.1mm closer to the suspension strut. The outer rim will poke out 31.1mm more than before."
    is this legal in nsw ????
    any help would be greatly appreciated. TIA
    Cheers, Zutta
    +17 offset would be the most offset you can go to, to be legal.
    A 9" wide rim isn't necessary though. 7.5" is sufficient.
      seems everthing i like only comes in 8 or 9 inch unfortunately.
      so +17 with a 7.5" inch rim ? or does it change with the 9inch rim ?
      cheers mate
        The offset does not change with the rim width.
