I know it is possible to fit GXL alloys/rims on GX prado as I've seen many PP have done it already. However, I am looking to do so in the near future and was working on the car when I noticed that there is a structure (not sure what it is, see below) on the inside of the front wheels with about 12-13mm clearance to the tyre. By my understanding (which I gather must be wrong) is that if you go from a 6 to 7.5 inch rim you will lose 19mm clearance on the inside and gain 19mm on the outside given offset remains the same (+30) ( http://www.1010tires.com/WheelOffsetCalculator.asp ). So a 7.5 rim with 265 tyre won't fit, yet many of you have done this upgrade. Could someone please explain how this works, are GX rims different offset to GXL?
[attachment=0:z9i974v6]DSC02173.JPG[/attachment:z9i974v6]
