what is legal
So time to replace the gradtreks is fast approaching after a bit less than 40,000k's
A quick read of these forums shows that in parts of the country, the max legal size increase is 15 mm
The Prado is supplied with dunlop AT 20 265/65R17. These have an outside diameter of 30.6 inches, with converts to about 777mm. Adding 15mm to these gives 792mm
I want (as do many) to go up as big as possible while staying within the legal limits.
For this reason I have been looking at 275/65R17 tyres.
yoko go12's are 795mm od
bfg are 792 mm od
d694 are 790 mm od
If we go by the actual size of the original tyres then the bfg and d694's are ok, but the yoko go12 is not (by about 3mm).
Is there a Standard Size for tyres ? or must we take the outside diameter of the grandtreks ?
Is any 275/65R17 ok ?
Are all 265/70R17 illegal ?
bfg are 792 mm od
d694 are 790 mm od
