Coopers Tires = BAD ???
  • #31
    Originally posted by wengnuts
    Originally posted by Snaga
    That post was goanna's thread and pics, not mine.
    I've been really happy with my ST's so far (fingers crossed as they say) and after the 10,000k rotation Hammond 4WD gave them the all clear.
    Are you considering trading the prado in for a Jeep? :lol:
    http://www.hammond4wd.com.au/
    :shock: :shock:
    This is their branding now http://www.tyresandmore.com.au/
    Although the other week when I had the 10,000k rotation done there was an awful lot of jeeps in the car park.
    Cheers, Leon
    Optix Photographix
    • #32
      They are a jeep shop prodominately, only took on the tyres in the last few years, they have been doing jeeps for 30 years, i had some work done their on my jeep.
      [b]Rob[/b]
      • #33
        George,
        the spare is a Toyo Opat AT in the same size, so no chance in them giving me a 5th tyre, I asked but they only laughed. The 4 Cooper tyres being replaced are from different batchs as the build date is different for all the tyres, I suggest anyone with these tyres to check them, from what I have seen they are splitting on the side with the white lettering, if your white lettering is on the inside you wont see the splits until you remove the tyres or crawl under to check them
        2007 D4D auto, Tunit Power Module, Scan GaugeII, Bilsteins & lovels HD, raised 50mm front & 60mm rear, 10,000lb Tmax winch, 7/16th Amsteelblue synthetic 23,000lb winch cable, TiTan HD winch solenoid pack, Outback draws with fridge slide & 50 litre Waeco, Ryno roof rack & Alloy Cage & extra set of Rhino HD Roof bars x 3, TJM type 15 steel Bullbar powder coated silver, Dual battery setup with custom tray, Bosch Navigator spots with 55w HID kit, Sand Grabber mats, Toyota Tow Bar, Sensor Touch Electric Brakes, Cooper ST 265/70/17 tyres, Uniden remote head UHF radio, Modified Milford Cargo Barrier, Extra power points in the back run with 10mm wire for fridge & inverter, Anderson plugs with 10mm wire front & back for the camper & compresor conections. 7 inch in dash JVC DVD player with bluetooth & Ipod adaptor, 39DB Stebel High Power TM80/2 Magnum Electric Horns. JL Audio 300/4, 300/2 power amps, Pioneer TS-C160R front splits & TS-D161S rear speakers & 12" Pioneer sub
        • #34
          Coopers replaced my front right that cracked without question. My other 3 have been fine so far, have just clicked over 10k with them. Very happy.
          2000 GXL. 3.4lt V6, ARB Sahara Bar, IPF's, foglights, 2 inch lift (OME), Cooper ST's 265/75/16
          GME 3600 UHF, Nokia CK-7W car Kit
          Soon to have HD Towbar and Snorkel. Maybe even lockers!
          • #35
            Had the 4 split tyres changed on Wednesday under warranty, had a wheel alignment at the same time, drives great now
            • #36
              Guys,
              I just replaced my first set of Cooper ST's (265x70x17) after having covered 125,000 km on them. I was so happy with them, I got another set of them.
              Mark
              '05 Prado GXL TD/Auto
              ARB bullbar
              12,000lb Ironman winch
              Brown Davis Bash Plate
              Ultimate Suspension
              Twin Hi-Clones
              DPChip
              Dual Batteries
              Safari Snorkel - Donaldson pre-cleaner
              Cooper ST's
              Outback Swan
              • #37
                Mark,
                Thats pretty good miledge, Hopefully I get as good a run as you have with my replacement set
                • #38
                  On another thread in here I posted pics of my ST's that have 50,000 on them. still a heap to go in the current environment that they are used.
                  I'll get them again.
                  Jeff.
                  W. C. Fields (1880 - 1946)
                  • #39
                    STs got hard compound in them so you can get high mileage out of them
                    but because of that they tend to chip badly when used in rocky areas like Vic High Country etc....
                    • #40
                      Im up to 75k on the STs on my Triton work truck, 265 75 16 with the heavy walls, these have been used hard since day one, used almost every day offroad, gravel roads and on rock, I run hard up against the GVM alll the time and run nitrogen to keep the pressure constant ( 40psi) There is definately some chipping, scratching and gouges of the lugs etc and they are pretty well worn but I couldnt be happier with how they have gone and will be definately going with them again, I havent had one single flat the whole time either.
                      • #41
                        Some great numbers in those mileages there... looking forward to getting similar myself
                        Cheers, Leon
                        Optix Photographix
