cooper st / bfg atr
  • cooper st / bfg atr
    Hi all,
    Standard height prado wish to fit cooper st or bfg atr
    had cooper b4 had a great run what will fit 265 or 275
    need to know if they foul any part of the inner fenders spacers etc dont know the profiles so
    Any input would be great ---andy
    2007 Grey Gxl, ARB bar ,Lightforce xgts HID100watt ,RFDS radio,Cooper St
    Icon radio,duel batterys, engel 40litre Raw 50mm lift
    Re: cooper st / bfg atr
    265/70R17
    275/65R17
    Both will fit without modifications to the suspension.
    However you will need a spacer for the spare tyre carrier on the rear door or the tyre will rub on the paintwork. You can make your own or I am currently organising the next batch for manufacture if you are interested.
    viewtopic.php?f=18&t=1571&p=115238#p114705
      @ amts, are these both cooper st and bfg atr sizes ---andy
        Does not matter which brand. Physically increasing the size of the tyre will make you loose the Hard Wheel Cover and you should get some sort of wheel spacer for the rear if you value the paintwork on the door. There is also an option for BFG or Bridgstones in the 265/65LT which could be the go depending upon what flicks your switches and how legally pedantic you want to be.
        Not sure on the 275/65 but I would stronly recommend doing something about your suspension if you go a 265/70 to reduce tyre rubbing on full lock.
        [COLOR=#000080]Nick[/COLOR]
          I run the Cooper ST 265/70 on my Prado. Had them fitted prior to my lift and found that they only slightly scrubbed on full lock, full compression. Now with my lift, doesn't even come close.
          As for 275, I can't help you there.
          AJ
          [i][size=2][color=#008000]2008 D4D GXL Auto [/color]- [u]BLACK[/u][/size]
          [size=2][color=#0000FF]- ARB Deluxe Bullbar - TJM Airtek Snorkel - Pirhana Dual Battery - BFG A/T's - Waeco 60L - Canvas Seat Covers - LED Spotties - Bilstein/Ridepro Lift - TJM Bashplate - GME TX3440 UHF - Rhino Roof Bars - Rooftop Tent & Awning - Poly-Airbags - ScanGauge II - Beaudesert 2.75" Exhaust - ARB Twin Motor Compressor [/color][/size][/i]
