Do 265/70 tyres on standard rim fit inside GXL carrier with spacer if necessary?
  • Do 265/70 tyres on standard rim fit inside GXL carrier with spacer if necessary?
    Hi all,
    I have searched high and low but cannot find an answer...
    I understand a spacer may be necessary to get the wheel away from the back door...
    But will the plastic painted GXL cover fit? Or does it only fit 265/65?
    Thanks!
    I think the answer is no, but seeking clarification
      Pretty sure no to both. Have a look through the 120 wheel and tyre section, this has been discussed before. Or google pradopoint+120+tyre+cover.
        The cover won't fit and the tyre will press on the plastic moulding rather than fitting in the recess on the back door. This size is very common though for the extra ground clearance you get and I believe they are now legal to fit in QLD. The diameter increase is 28 mm and I believe we are permitted 50 mm up from 15 mm previously. https://www.tmr.qld.gov.au/Safety/Ve...-modifications
        2008 D4D GXL
          thanks all ended up going with std size
