Powder coated bull bar
  • Powder coated bull bar
    I have recently made enquiries regarding fitting a steel ARB bull bar to suit my new Kakadu, I was advised not to have one colour coded "crystal pearl" to match the car, as this colour is very difficult to match.
    The 4x4 shop recommended fitting and aluminium bar instead.
    Has anyone any thoughts on this:?
    So what would the crash repairers do if you had an accident? they would have to match the colour. No way they would write off a kakadu because it had a small dent and was to hard to match the colour. Difficult surely doesn't mean impossible, get what you want, not what the 4x4 shop thinks will be easiest for them.
      I had no problem, gave them the paint code and the colour is fine.
      Prado 150 GXL - V6 Auto, ABR-SIDEWINDER Dual battery System, Tekonsha P3, 50mm Lift kit - King Springs & Bilstein Shocks, Polyair Bags, BFG 275/65R17 Tyres, Milford Cargo Barrier, ERPS Extreme use 10 coupler rust protection, Rhino Rack, Factory Towbar, ABR-SIDEWINDER fridge/freezer, ABR-SIDEWINDER compressor and PSV deflators, Twin Drawer system, Fridge Slide, Twin 23L water tanks, 80W Solar Panel, Hot Water Shower, ARB Awning, Toyota Seat Covers, ARB Winch Bar, Warn XD9000, HID's, Snorkel .
      My website: [url]http://www.sidewinder.com.au/[/url]
        My 120 is "crystal pearl", and I had the bar color coded.
        Match is pretty close, not perfect, but takes a close look to notice the difference. I know there's a difference but most can't see it.
        I think part of the issue is that "crystal pearl" takes on different hues depending on the viewing angle and ambient light, and this creates perceived difference between flat surfaces of the bull bar and curved body panel surfaces.
        Ex 1988 Mitsubishi Pajero V6
        Ex 1986 Suzuki Sierra
          it is impossible to match a 3 layer pearl, such as toyotas crystal pearl. But as from rhs58's experience you can, if your lucky, get it pretty close. In an accident repair situation, you will find that the colour is blended through adjoining panels so as to give the illusion that the colour is accurate. It is also more expensive to repair for this reason.
          You need to match two colours to achieve the finish. first is a solid base coat of white, then a transparent coat, which contains the pearl effect. trust me when i say thats its very difficult. Most paint company's do have formulations but they can be very hit and miss. Considering the time it takes to match, most shops will just spray the formulations and hope for the best.
          Its a gamble to colour code 3 layer pearls, but when done right, F#@king awesome!!!!!!
          1st 2005 V6 auto in white.
          2nd 2008 D4D auto in charcoal
          3rd 2014 D4D auto in white
            OK, next question!!!
            Should I go with an aluminium bar, what are the pro's and cons?
            I intend to use my Kakadu in WA, staying in outback stations and day tripping using these as a base camp. Also joining a 4x4 club to do the ususl trips in a club environment. (no rock wall climbing or river crossing etc.).
              I got the ARB bar with matching pearl. You have to look really hard to see the difference. I just love the bar. Bugs come off easily with bug remover.
              [SIZE=1]Cheers Jim.
              [/SIZE][COLOR=#0000cd]
                Hey guys, The White Pearl is a hard colour to match,but they do a good job of it.
                I'm a spray painter by trade and i'd say definetly go the colour coded bar,we have done several done here at thornleigh in the pearl white and they turned out pretty good (to my standards atleast..which are pretty high).
                  law suit? what about?
                  2011 150series GXL
                    After colour coding my bars I wouldn't do it again. The painter managed to match the Blue Storm really well (although this is easier than the pearl) and it looked good to start with but when taken off road it voids what I've put the bar work on there for.
                    After 2-3 offroad trips the paint is scratched and chipped, something that I've never experienced with standard Black Powdercoated barwork due to the strength of powdercoating.
                    After my Cape York trip next year I intend to remove all the bar work and powder coat it silver/grey to match my alloy wheels, won't be colour coded but won't be the standard boring black bar work either.
                    Don't go alloy.......... too weak. Only good if you want it to look like it's taken off road not actually taken off road.
                    I went with an Ironman bar as it is a copy of the ARB from what I've seen but was cheaper. Very happy with it.
                      Steel, aluminum is as useless as the foil namesake.
                      Colour code it. My silver does not match perfect but it looks good. As for chipping, well there are serious paint gouges all over the rig, they are called battle scars and a glass of HTFU will generally fix this ;p
