Toggle/rocker switches
  • Toggle/rocker switches
    At the moment, I am about to fit a set of IPF Driving Lights to my 2010 GXL Prado. I want to wire my Driving Light through a seperate switch positioned on the dash so that they will only be activated whilst this switch is turned 'on' with the car's highbeam is ön". Can anyone give me advice as to where I can puchase a 'Toggle/Rocker' switch that will fit in one of the spare locations on the dash. I haven't checked yet, but is my only alternative, contact Toyota for a genuine Toyota switch (that's if they make them)........ How to run the wiring is not a problem, but, just where to purchase a 'Toggle/Rocker Switch'.
    Thank's.
    http://www.customrockers.com.au/epages/cucu3398.sf
    This is the ARB tpe switch. There are pics on my rig build up see: http://www.pradopoint.com/showthread...ande-MLC/page5
      ABR Sidewinder has a wiring loom including a factory style switch that looks the goods and fits for about $30.
        thats what i did, just purchased the entire loom. the switches are quite good.
        2011 150series GXL
          You can get the ARB style Carling switches from these guys. Postage is pretty good (I got 6 switches, a 6 switch panel and a sheet of the switch labels posted for 10 pound)
          http://www.mudstuff.co.uk/Carling_Switches.shtml
            this is where I have looked
            http://www.newpro-tech.com.au/
            2011 VX T/D auto pearl white, 3" exhaust and [COLOR="#FF0000"]CHIP IT [/COLOR]module and Auber EGT gauge. Daul battery fitted cig and engel plug in cargo area and charge wires run for the camper. Dual DVD headrests and Extinx GPS/DVD unit. ScangaugeII.
              as per sbclover, I have just ordered one from http://www.newpro-tech.com.au/gallery10.htm . I will post some info after I have received it and had it connected.
              smakb
              Stephen Bloomer
                sbclover and smakb,
                Those switches look the goods, I see there are 2 listed for the 150,
                Price $29.95
                Factory fitting Toyota light switch kit.
                NPT-LS-15
                and
                Price $50.00
                Two Factory fitting Toyota light switch kits.
                NPT-LS-15T
                any idea what the difference, other than $20.05, is?
                  one pack has one switch, the other pack has two switches...
                  2011 150series GXL
                    I just wish they did the same switch for Air and lockers
                    Stephen Bloomer
                      Hmm, personal taste I guess. I am contemplating changing all my original switches to the ARB type.
                        Wooley,
                        Oops, it still took me a while to see it,
                          There's no reason you can't use those switches... Just stick a little label on them so you know what they are. Still neater than arb switches
                          2011 150series GXL
                            i just go to the pick a part and get toyota switches out of any type of yota...
                            Front and Rear ARB Air Lockers - Maxxis Bighorn 32inch M/Ts - Black 16x8 Sunrasias - Bilstein shocks - Lovells springs - Duel batteries - Ironman winch bar - Safari snorkel - Turbo timer - Boost guage - 3 inch mandrel bent exhaust - DP chip - Diff breathers - Custom Drawers - Towbar - Cargo barrier - HID spotties - Roof cage - Rear floodlight - Arb compressor - Garmin 1490T with Topos - 12000 Winch - Ozito chainsaw blah blah blah
                              Beware of some of the dash switches that are about at the moment...The internals of the switches have some very sloppy soldering...I got a pair from a certain supplier and the monent that the power is connected the backlighting comes on ....even tried it with just hooking the red wire to the battery and the black to earth and Bingo the light is on !!! The model number of some of the "effected switches is NT-P-2015..."apparently" there was a "Bad Batch" from China...
