Number plate aerial mount
  • Number plate aerial mount
    Hi all, has enyone fitted a UHF aerial to a number plate mount. I was thinking of the mounts they put behined the number plate and mount driving lights to? Yes I have done a search of PP no luck.
    Thanks Colin
    I did look into it and there are a couple of generic numberplate fittings you can get to do the job. Just don't try and fit a big heavy aerial and you will be right. I decided to wait and get the bull bar
    Stephen Bloomer
      You mean one of these jobbies?
        I had one of those until I got my bullbar. I wouldn't want to mount spotties on there but it was OK for the aerial I had. The one thing I did do was to fit some steel brackets from the back of it through the grill onto the metal bumper - I felt that without that it wobbled around too much. Hope that helps. It also looks a bit out of place (read girlie) on the front of a Prado
        Trekrider
        Banned
          Hi All thanks for your replies
          Yes thats the Jobbies I was thinking about thanks Mumsrig
          Thanks also for the picture Treckrider, yes looks a lot girlie may need to look at A nuge bar I think.
          Colin
            Colin
            No worries Colin - I took a bit of stick when I first posted the picture I have moved on a bit since then though
            PS I still have it if you want one - just cost you postage.
              Hi Trekrider, thanks for the offer. I'll give a miss and save up for the nuge bar.
              Colin
                Colin
                No worries Colin - a very wise choice
