Since having the Airtec installed my car has a distinct loss of power at medium throttle ???anyone else had this ?
Loss of power since snorkel install v6 ??
Originally posted by timmay5.7 View PostSure its not the weight of the bull bar on the front slowing ya down?2010 Kakadu with all the usual stuff.... Build up thread below
Daz make sure they have plugged the air box sensor back in or un plug it and re plug it in. Usually if this was unplugged if would result in a check engine light but I have seen it not do that as well.-----------------------
Daniel
Originally posted by Rogerthatv2 View PostDaz make sure they have plugged the air box sensor back in or un plug it and re plug it in. Usually if this was unplugged if would result in a check engine light but I have seen it not do that as well.
I also pulled the innergaurd cover off and found all was good no kinks it's actually solid plastic that can't kink, the air pickup hole in the air box is surprisingly small from the factory It sits partway in the air box then leads through the guard it very small internally but I guess Toyota would/should size it right.2010 Kakadu with all the usual stuff.... Build up thread below
Ok since cleaning my filter it seemed to power up a little but its been more a coincidence but a couple of times the car has seemed to have dropped power but today when it did it my window was down and I could hear the viscous cooling van, once the fan cycled off power was spot on. I think the times I was accelerating after the snorkel install and feeling lack of power was when the fan was robbing power each time...Doh2010 Kakadu with all the usual stuff.... Build up thread below
