150 snorkel vibrating
  • 150 snorkel vibrating
    My snorkel vibrates against the body with the engine idling and the ac on . Any ideas please ?
    Cheers Ross
    Mine does the same. Not sure what you can do though, however it is very annoying and can't be good for the fixings.
    2011 150series GXL
      What brand? I have the Safari and it is rock solid.
      Steve.
      Stephen Bloomer
        Glad I didnt fit a snorkel to "fix" my 1500 rpm drone/rattle......
          I've got the airtec and it's been fine. Only been fitted for a couple of months though.
          [SIZE=1][B][COLOR=#ff0000]2010 Silver GXL Prado T/D Auto.
          [/COLOR][COLOR=#0000ff]2014 Leisure Matters X-Track Camper Trailer.[/COLOR][/B][/SIZE]
            When mine started that it did an injector.............hope this isnt the case with yours.
            Peter
              Peter
              Interesting. Did Toyota just pick it up in a service or did it make itself known?
              2011 150series GXL
                It's a Safari snorkel , the vibration has started with the hot weather and using the A/C . I'm wondering if there's any adjustment possible at the mounting bracket on the pillar to move the snorkel out from the body ?
                Cheers Ross
                  Mine was doing that. What it was, was a loose bolt which is located under the air filter in the air box itself. So open your air box pull your filter out and you will see two bolts that hold the air box to the vehicle body. Under those bolts are a rubber bushing with a metal rod through the center of it. These will most probably be worn and need replacing if the bolts are still tight.
                    It made itself known.............got to the stage where it wouldnt tow my van.
                      Just had a Safari snorkel fitted by ARB and we have a rattle when first starts up this last for a minute or two until it has warmed up. The sales persons from ARB said his did it to and was a rattle in the motor that was being accentuated by the snorkel being fitted, can anyone shed some more light on this for us?
                        I had an airtec fitted by TJM, had a rattle and annoyed the piss out of me. Found out the meshing on the inlet is reasonably loose in the slot. A little tap here and there fixed it.
                          I had an airtec fitted by TJM which developed a rattle. It was just the poor installation effort. Two self tappers drilled into frame which they managed to stripped. So I ended up replacing them with nutserts. Problem solved and lesson learned about TJM installation.
                            Mine was actually pop rivetted to the pillar.
                            [b]Rob[/b]
                              Just goes to show how different stores do things differently Hutch. Like Wazza said in the other post if I need TJM products in the future I will head to Brendale, will certainly never give any more money to Coopers Plains for installation.
