Wanted Crago Barrier GX ( mine site spec)
  • Wanted Crago Barrier GX ( mine site spec)
    Well i have a problem.
    I need a cargo barrier to fit my 150 GX Prado, but with the rear airbags they cut away the top corners leaving a huge area each side for projectiles to fly through.
    I have done some shopping around with little help here and on mine sites this cutout isnt good enough.
    Can anyone send/post me details of a full/Half barrier that dosnt have the cut outs.
    Any help will be appreciated.
    Havnt checked again but there is/was a cargo barrier on ebay that come out of a mine vehicle may suit your needs, you obviously dont have kids/adults sitting behind the drivers or passengers seats ?? as you would know by having a barrier impeding on the airbag system would/could be an insurance issue ?? Will check ebay and see if I can find it, it may have been for a 120 .Cheers Steve
      Toyota standard cargo carrier for my GX came with no side cutouts. I know the pic in e brochure shows cutouts, but mine definitely doesn't have them.
        Toyotas 5 seat barrier has no cut outs...
        2011 150series GXL
          Hi CBM8880
          Can you send me the part number you have, and a picture please.
          Thanks in advance
            Hi Brindo, I'll check it out when I get home on Fri and send you the number. As suggested above, ask Toyota as the 5 seater cargo barrier shouldn't have cutouts.
            Cheers.
              If i get mine back before then i will let you know, toyota barrier and contoured to the head liner
              2011 GX TJM type 13, Airtec snorkel, TJM bash plates, Gensis HID lights & a few antenna's
