Removing stock roof rails on a 150
  • Removing stock roof rails on a 150
    Searched and no luck..
    I want to carefully remove my stock GXL roofrails so I can fit up my windcheeta alloy rack.
    Has anyone had a go at doing this ? How do you go about it ?
    [CENTER][B][U]Matt
    [/CENTER]
    [SIZE=2]
    [/SIZE][CENTER][SIZE=2]
    [/SIZE][/CENTER]
    Try this one Matt that was posted sometime ago for 120 Grande Roof Rails removal
      Yep, the 150 is the same as in that post. Takes a bit of force to get some of the covers off, well, more than I expected anyway, but I didn't break anything so that's a bonus
      Dave.
      Silver 150 D4D Manual. ARB winch bar, Safari snorkel, Tigerz11 12000lb 2 speed winch, Lightforce 70W HID XGTs, ABR Sidewinder dual battery system, ABR air compressor, Powerful 4X4 roof rack, Tigerz11 awning, ARB imitation rooftop tent, 40L Gold Engel to keep the Coke cold.
        Hey Matt,
        I have the same job planned for this weekend too or maybe it will be Monday. I'll keep an eye out for any new tips, but it sounds like it's all the same as the 120. I'll have to review my old post... thank goodness for the archive .
        LFaR.
          I hear ya Matt.
          I don't need to do the job until the end if the month. If I sort it, I will post pics and info.
          [CENTER][B][U]Matt
          [/CENTER]
          [SIZE=2]
          [/SIZE][/CENTER]
            I followed the instructions as per the post Craigm gave the link to. Pretty straight forward.
            Only tip I would add is how you can avoid using a knife altogether. I shoved some dyneema cord in the gap as soon as I pushed or pulled one of the covers. any cord would do it and save possible scratching from a knife slip. Just pull the cover and shove the cord in the gap to prevent that part of the cover from locking back onto it's clip. Repeat for the other parts of the cover that are locked in and before you know it the cover can be removed.
            While I like the look of the factory rails, I like the look and practicality of my triple crossbar rhino racks more. W
              I did mine last week and it was very easy. I waited until the plastic heated up in the sun and then starting at the front and from the pointy end of the cover eased in a flat blade screw driver. Once you get the two lugs to pop off on the first side it will lift off by its self. Follow the guide above and you cant go wrong.
                Excellent post, will remember this one for when I change my racks over, got my eye on a windcheater style rack, need the low height for the garage and versatility of being able to mount my Kayak racks on as well.
                Only down side I can see is not being able to clean the roof after its installed - any thoughts?
                Kev,
                  Hi Craig
                  As a newby to Pradopoint -how do I view your post? It doesn't appear in your message
                  cheers
                  Grant
                    Originally posted by Gbp View Post
                    Hi Craig
                    cheers
                    Grant
                    Welcome to PP!
                    I hope this is what you are seeking - Try clicking here:
                    http://www.pradopoint.com/showthread...l=1#post201280
                    Spilsy
                      One of these should do the trick, it's what I use (disclaimer: I have the Pioneer Platform and factory rails) :- http://www.bunnings.com.au/sabco-xl-...e-mop_p4480228
