150 Nudge bar pictures thread...
Hi sweet pea... By the way, if you have a secondhand bar and want to make it look like new, try the following like I did.
Alusol polish brings the metal up nice and shiny.
Peanut paste does the same on the black plastic.. No kidding2012 Crystal Pearl Prado Altitude 150 Diesel Auto. Toyota mats and rear rubber mat. Toyo Open Country AT2's 265 65 R17 LT. OEM nudge bar. dual battery set up with Optima D34, rear power points front and rear Anderson plugs. Lightforce LED combi light bar. Kingsley side steps. Outback Ideas recovery points. Dr Air Pro 150 ltr air compressor. ARB 60 ltr fridge. GME 3550s UHF radio. Hema HX1.
Originally posted by Piratepete View PostHi sweet pea... By the way, if you have a secondhand bar and want to make it look like new, try the following like I did.
I was looking for a second hand nudge bar to mount the multitap HF antenna onto.
I am looking for something I can put on and take off relatively easily and removing the front bumper doesn't fit my idea of relatively easy.
Thanks for your advice. You were the first to confirm that I actually needed to remove the bumper to fit the genuine bar.
The third party nudge bars that mount under the bumperbar are looking more suitable.
S.155 SX with dual battery and Polyairs in the rear springs..
Originally posted by Piratepete View PostGot my 2nd hand nudge bar off gumtree for $80. Normal retail about $600 for the OEM nudge bar. Local dealer CMI Toyota at Cheltenham kindly printed off install for the nudge bar for me. Fitting instructions say 1 hour.. Took me 6 hours and with some panic. have Altitude with front sensors, no problem at all with operation.
Are you able to scan the instruction and upload/email me a copy? Just pick up a 2nd Nudge bar as well, just need instruction on how to install it.
Hi Khoa.. Best to go to Toyota dealer. Instructions have a template you have to use to cut plastic under the radiator. I threw the template away after I finished it. (See my earlier comments) . No problems with the dealer printing them off for me.
Took me 6 hours not 1 hour to fit as it says on the instructions. Good luck.2012 Crystal Pearl Prado Altitude 150 Diesel Auto. Toyota mats and rear rubber mat. Toyo Open Country AT2's 265 65 R17 LT. OEM nudge bar. dual battery set up with Optima D34, rear power points front and rear Anderson plugs. Lightforce LED combi light bar. Kingsley side steps. Outback Ideas recovery points. Dr Air Pro 150 ltr air compressor. ARB 60 ltr fridge. GME 3550s UHF radio. Hema HX1.
Originally posted by Piratepete View PostHi Khoa.. Best to go to Toyota dealer. Instructions have a template you have to use to cut plastic under the radiator. I threw the template away after I finished it. (See my earlier comments) . No problems with the dealer printing them off for me.
Anyhow, i got a copy in PDF. Did they print it out in A4 format for you Pete?
And yes, the fella i spoke to said his Tech team take around 4hrs plus to fit them. I'll see if i can beat their time .
Hi Khoa, yeah they only gave me a printed A4 copy. I should've copied it before I used the template. I dont think I'm gonna take the nudge bar off because I don't need a bull bar for the amount of off roading I do. Really happy with the look of the 75mm tube. Follow the instructions to the letter & you will be fine. Pretty scary when you have the front end off though. If you are gonna put recovery points on, now is the time to do it with the front end off. I got the Offroad Acessories ones from TJM.2012 Crystal Pearl Prado Altitude 150 Diesel Auto. Toyota mats and rear rubber mat. Toyo Open Country AT2's 265 65 R17 LT. OEM nudge bar. dual battery set up with Optima D34, rear power points front and rear Anderson plugs. Lightforce LED combi light bar. Kingsley side steps. Outback Ideas recovery points. Dr Air Pro 150 ltr air compressor. ARB 60 ltr fridge. GME 3550s UHF radio. Hema HX1.
Good morning Khoa do you still have the instruction how to fit the original toyota nudge bar.I just bought secondhand one my self and I need instruction to fit to my Prado 150 2015.I appreciate if you can email it to me [email protected].I have to luck asking to toyota about the instruction.Could you please send me a copy.Thank you very much.
Hey teddy, if you have a 2015 facelift, it is a different nudge bar and fitting compared to the pre facelift models. You will need to get hold of the relevant instructions2012 Crystal Pearl Prado Altitude 150 Diesel Auto. Toyota mats and rear rubber mat. Toyo Open Country AT2's 265 65 R17 LT. OEM nudge bar. dual battery set up with Optima D34, rear power points front and rear Anderson plugs. Lightforce LED combi light bar. Kingsley side steps. Outback Ideas recovery points. Dr Air Pro 150 ltr air compressor. ARB 60 ltr fridge. GME 3550s UHF radio. Hema HX1.
Nudge Bar Installation Instructions
Bought my 2015 GXL new with nudge bar fitted. The instructions which came with the car are for Production Dates - August 2013 onward. So it looks to me like facelift made no difference.
I am confident the fitter used these instructions because page 12 is the air deflector template and it has been cut out of the page.
PM me your email if you want scans.
cheers,
Max
Ok thanks I will check it tomorrow arvo for the picture and can you send me the instruction too [email protected].
Good morning Puddock any chance taking some pictures of the nudge bar cut outs and installation instruction you can pm on [email protected] ...Thank you very much
