ARB 150 Series Front / Side Rails Discontinued
  • #76
    TJM no drilling if the chassis.
    [b]Rob[/b]
    • #77
      Sounds like ARB are the go or TJM if you dont want to spend more that a grand
      might be some good deals going at the Camp/4x4 super show
      2010 GXL D4D manual, Cooper ST, Piranha dual Battery system, ARB bar,2inch OME lift,black widow draws,tigers 11 winch,
      • #78
        Superior Engineering have a set of sliders on their webpage now as well. Im not sure if these are their own design or what the quality is like, just saw them when browsing.
        • #79
          Both TJM and ARB r good quality, the differences are the the ARB are a bit longer and sit under the sill like the original step, the TJM is a little shorter and sits up a lot more in line with sill, gives a bit more clearance, the TJM also sits out past the doors panels stops the idiots opening doors on to your door panels. Hope this helps.
          [b]Rob[/b]
          • #80
            Check Dainels vs mine in these photos
            [b]Rob[/b]
            • #81
              Hi Guys,
              Had mine fitted, see my build thread for photos. Very happy with them. Insane mounting system, solid as.
              http://www.pradopoint.com/showthread...l=1#post404034
              • #82
                Hi Guys,
