My 60l fridge is on the left and the 40l freezer is on the right. Something to consider when you find that one fridge/freezer just isn't enough for those big trips. I did have one Engel in the rear as a freezer and another Engel with the extended lid as a fridge on the floor behind the front passenger seat after completely removing the middle row of seats. This was a pain because it was a real B to get in and out and the lid wouldn't open fully. Another thing to consider is how far will your door open if you have a trailer/van hitched up? Opening my door fully, I can slide out either fridge and stand on the trailer hitch to get into the fridge. Sometimes, dependent on ground level and alignment with the trailer I can't open the door fully so am unable to access the right side fridge.
Fridge Mounting
Thanks. Keep the suggestions coming. I won't be using a van or trailer - I am an oztenter. I am able to fully open back door without obstruction.Prado GXL 2012 Charcoal - Drifta Drawers, Cargo Barrier, Sidewinder Dual Battery kit, Ironman Bar, Narva lights, Safari Snorkel, Airbags, TX3350 kit, Waeco CFX65DZ - often seen with Thule 2.2M narrow roof pod and towing 2014 Kimberley Kamper. Could be anywhere!
Thanks for the responses. I just purchased a Waeco CFX65DZ. Yeehah! 25% off at the big snake shopPrado GXL 2012 Charcoal - Drifta Drawers, Cargo Barrier, Sidewinder Dual Battery kit, Ironman Bar, Narva lights, Safari Snorkel, Airbags, TX3350 kit, Waeco CFX65DZ - often seen with Thule 2.2M narrow roof pod and towing 2014 Kimberley Kamper. Could be anywhere!
Hi
I am also looking at keeping the 3rd of seats, however both can be folded away when I want to travel.
please can someone post pictures on how the false floor is secured over the 3rd. row of seats. I have tried and the weight of the drop down fridge lifts the 3rd of seats. The other problem when the 3rd row of seats are folded away the floor is not level as others have shown on this thread.
I am not sure what mount points are use.Regards SAFTGT
2010 Prado GXL, Engel 40L drop slide, Dual battery, ARB CKMA12 Compressor, Micky Thompson.
Thems long bolts!Originally posted by OutdoorsMan View PostI just used the factory tie down points on the rear of the 3rd row seats. Remove factory tie downs, install false floor, insert new M6 x 400mm Bolts. Job done.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
So how did you remove the factory tie down points? I've made a false floor from ply and carpeted it, but simply made holes through the ply to use the factory tie downs for the fridge on one side and a storage box on the other. It's OK but I'd originally wanted to bolt it down but couldn't work out how. Any advice appreciated.Originally posted by OutdoorsMan View PostI just used the factory tie down points on the rear of the 3rd row seats. Remove factory tie downs, install false floor, insert new M6 x 400mm Bolts. Job done.
Not 100% sure what you are asking. The factory tie down points have a plastic tab which you lift to expose the bolt. To reuse the tiedowns you will need to make a recess in the ply floor and use longer bolts.
http://www.pradopoint.com.au/showthr...l=1#post398578My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
HI, I have change to a upright Kings 85 liter fridge with a 5 year warranty. No 42 kg slide needed and so much easier to find the beers. I made a wooden frame. Bolted the fridge to the frame and used standard door hinges to "plug and play" the fridge when required. The hinges are screwed to the false floor.Regards SAFTGT
