On a 120 the bonnet scoop directs air through the intercooler which is on top of the engine. On a 150 the intercooler is in front of the engine/radiator so fitting a scoop will only be for aesthetic reasons.
When stationary for a period of time or travelling at very low speed it would assist in removing heat a lot quicker reducing the effects of heat soak, one would think. It would look good if you had all the other gear on as well like bull bar etc.
You only live once and you need to spend your money on something... Go for it
It can be very dicey fitting scoops to things that dont have scoops. Reason is to do with high and low pressure systems infront and behind the radiator. Most vehicles operate with a low pressure system behind the radiator to help draw air through and down out the tunnel.
Sometimes if you fit a scoop it can create a high pressure behind the radiator which can increase engine temps as the air movement through the radiator can be reduced.
Chris
EDIT*
Over on the LCOOL forum a similar topic has come up.
The 150 must have one of the worst intercoolers ever for a factory car. I wonder how it could possibly work. The airflow would be terrible with the ridiculous 90 degree bends in and out. It would be lucky if even half of the intercooler core actually does anything. With the A/C condensor sitting in front it is more like an interwarmer than cooler. I am waiting for someone to bring out a water to air intercooler kit, there must be some serious airflow restriction and HP losses with the existing 'cooler.
150 Vx D4D, Deluxe Arb bar, winch, Hayman Reece Towbar, UBP, P3 Tekonsha, 'n stuff.
"When cooking on a camp fire it must be cool enough to cook on so it needs to burn down to coals, at least in parts. It is customary to drink beer while waiting for the fire to cool down.
I recommend starting with a very big fire"-Vince.
