i have no need for fog lights, si i was starting to think about puting spot lights in there place, has anyone done this on the current style bar?
spot light to replace fog lights in arb deluxe bar
Whilst not "spotlights" per se, has anybody checked out these?
http://www.ebay.com.au/itm/2x-WHITEV.../251907384054?
They appear to be the right size, but would you not need a bracket to be fabricated to allow them to be installed securely?Prado 150 D4D AUTO GXL with ARB Deluxe Winchbar, Brains' TG150 Transfer Case Actuator Guard, Bilstein/Ridepro 50mm Lift, Safari Snorkel, D697 265/65/17 LTs, Dual Battery Setup with REDARC Controller, REDARC Tow Pro, Toyota Tow Bar, Maxtrax - towing a Camprite TL8s fitted with GXL wheels and D697s.
I am going to fit Narva DRLs to the C ute Deluxe bar one of these days... Looks to be relatively straight forward. I have done the same on the T3 on the 150.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
The DRLs fit easily if you are prepared to sacrifice the fog light plastic frame and use that as a mount. 3163014L was the part number of the left hand frame. Not sure if that is the same as the infill panels on the Prado deluxe bar.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
