Domin8or Winch Install - Guidance, Tips, Tricks & Gotcha's?
  • Domin8or Winch Install - Guidance, Tips, Tricks & Gotcha's?
    Hi Guys,
    Going to get a Domin8or winch installed on the Prado this weekend and seeking tips, tricks and notable gotchas for the install.
    * Do I need an offset hawse?
    * Do I need to take the bulbar off?
    * Did you need to purchase longer mounting bolts?
    Cheers!
    Frank
    2014 Toyota Prado 150 D4D Auto (facelift); ARB Deluxe Bullbar; OME 2" Lift; Rhino Pioneer Platform Rack; Redarc BCDC 1225 with Optima Yellow Top; BF Goodrich Mud Terrain KM2; Lightforce Genuine Custom 70w HID; GME UHF; Safari Snorkel; Rigid Industry SR-Q2 side lights (yet to be installed); Domin8or winch (yet to be installed)
    I'm not in any way familiar with that winch and have no idea what bullbar you have, but I installed my winch (Ironman) into my TJM myself and removed it as well and found that I had to take the bullbar off to get the winch in. Even if I didn't have to I reckon overall it would've made the job a lot easier anyway. I do recommend having a second person help you put the bullbar back on once the winch is bolted in because it will be damn heavy!.
    2010 GX Turbo Diesel
      Overall a seamless install really; didn't have to take off the bulbar. A couple of things I will recommend though:
      * replace the bolts that came with the winch with high tensile ones,
      * the hawse fairlead require longer bolts (35mm instead of 30mm).
