Cargo Barrier Considerations and Mount/Dismount Speed after initial installation?
  • Cargo Barrier Considerations and Mount/Dismount Speed after initial installation?
    It would be great to get some feedback on considerations for cargo barriers.
    - How long people find it takes to put in and out once the initial installation is set up?
    - ie. Milford say theirs is "easy" to install without the need for tools but how do others compare?
    Caddy storage. 4 bolts to do/in do once the install is done. Takes less than 5 minutes. If I had my time again I'd go half height and not full height so I could have a water tank between it and the drawers/back seats
    Can't comment on the install as they did it for me in about 20mins
    http://www.caddystorage.com.au/produ...barrier-types/
      Genuine Toyota is a bugger to put in and take out
      [B]Steve[/B]
        I've had the full height milford one for a few years now. It is genuinely a 2 minute job. You don't need any tools either. You do lose a bit of boot space down low and I would consider a half height one next time to maximize the rear load space.
        The milford one also allows rear passengers to put the rear seats partially back, but not fully reclined.
          Check out one of our members (Tin175) Light Cargo/Pet Barrier. I purchased one, took all of 15 minutes to install. Great piece of kit.
          http://www.pradopoint.com/showthread...go-Pet-Barrier
            What paddyb said. In addition Tin175 barrier also lets you use the range of fore / aft adjustment for the second row seats.
              I got the Milford unit for my 150. Piece of pi$$ to install and remove.
                Thanks for the info. I purchased the Tin175 Light Cargo/Pet Barrier and it seems to be a really good option.
