Towbar ball weight
  • Towbar ball weight
    I have been lookinf through all the specs and I can find the towing capacity but no info on ball weight.
    If anyone knows, can you let me know.
    Also, do you think the ball weight will be greater on the SWB since the towing capacity is higher?
    Thanks,
    Adam
    2010 ZR 150
    1987 Range Rover Ute
    Re: Towbar ball weight
    Adam,
    The towball weight is general 10 % on the ball.
    for the LWB towing is 2500KG then the max weight on thr ball is 250KG.
    On the SWB is 3000kg towing therefore 300kg on the ball .
    Hope that helps
    Peter
      I don't think you can always assume that nowdays. I was looking around and there are plenty of vehicles now with a 2500 tow capacity but only 180 ball weight.
      Thanks,
      Adam
      2010 ZR 150
        The ball weight on the Prado 120 is 250kg
        Don't know what the new one is
        December 2007 Prado GXL diesel, Option Pack with traction control, rear airconditioning and curtain airbags. Lovells Springs and Bilstiens shocks, snorkel, front recovery points,
        ARB Bar with fog lights, ARB second battery system, sandgrabber mats, Pirelli ATR Tyres,
          Thanks. I would assume it is the same on the 150
          Thanks,
          Adam
          2010 ZR 150
            You can't assume anything in regard to towbars and weights - to me it doesn't make sense that the shorter, lighter, three door isn't going to get pushed around as much by a three tonne caravan as the heavier five door which is only rated at two and a half. if someone already has one with a tow bar there should be a plate on it stating the tow ball weight.
            Doug
            [b]Doug[/b]
            2011 Blue Storm GX D4D
            My Rig Build Up [url]http://www.pradopoint.com/showthread.php?19507-Doug-s-2011-Blue-Storm-GX[/url]
              Doug
              250kgs
              Geoff
              2009 150 series Silver VX auto V6
                Doug
                250kgs
                Quote from Toyota: "The maximum towball weight for the five door Prado is 300 kgs"
                [FONT="Arial"][SIZE="1"][color=#008040]Was Prado 150 GXL T/D auto, graphite, tint, factory towbar, D697LT, Autosafe cargo barrier, ARB deluxe bar, ABR-Sidewinder dual battery & monitor, GME TX3440, ARB fridge, Safari snorkel, Maxtrax, Tekonsha P3, ScanGaugeII, OME suspension, Tigerz11 winch, TG150, Now Jeep Grand Cherokee Laredo with QL and ORAII[/size][/color][/FONT]
                  Doug
                  250kgs
                  That's strange because on the actual tow bar it says 250kgs.
                  Geoff
                    Yep, sticker on mine definitely says 250kg
                    2009 Silver Prado 150 Kakadu, Towbar & Roofracks
                      I can confirm a 3 door is 300 kg ball weight I have a genuine towbar in my garage awaiting the delivery of my 3 x door.
