Driving lights, which ones to fit to the 150???
    Re: Driving lights, which ones to fit to the 150???
    Thanks pretty much decided on them myself at the weekend after attending the Brisbane 4 x 4 show
    150 Silver Diesel GXL Auto with ECB Bullbar, Toyota Factory towbar, Black Widow Drawer system with Fridge slide and cargo barrier, GME UHF 3340 Radio, Waeco 50 Litre Fridge, Rhino Racks and Rhino Basket, ARB Awning, IPF XS Spotties, ABR Sidewinder Dual Battery system,Airtec Snorkel, Bilstien Shockies, King Springs, Poly Airbags and BFG A/T''s. Now towing a semi offroad Lotus Freelander 18.6 Van, with all the bells and whistles.
      I will have my ARB winch bar and Warn winch fitted on the 14th of April and post some pictures of the ABR-SIDEWINDER HID's soon after. They are 205mm and should be a good size.
      Regards
      Derek.
      Prado 150 GXL - V6 Auto, ABR-SIDEWINDER Dual battery System, Tekonsha P3, 50mm Lift kit - King Springs & Bilstein Shocks, Polyair Bags, BFG 275/65R17 Tyres, Milford Cargo Barrier, ERPS Extreme use 10 coupler rust protection, Rhino Rack, Factory Towbar, ABR-SIDEWINDER fridge/freezer, ABR-SIDEWINDER compressor and PSV deflators, Twin Drawer system, Fridge Slide, Twin 23L water tanks, 80W Solar Panel, Hot Water Shower, ARB Awning, Toyota Seat Covers, ARB Winch Bar, Warn XD9000, HID's, Snorkel .
      My website: [url]http://www.sidewinder.com.au/[/url]
        I have just got my GXL prado and have fitted a ARB bullbar, already have bought a set of Narva 225. Not sure to fit them after ready the problems you might have on heating
          i fit a set of lightforce xgts to the front last night, took it for a run today out and about doing some track work and through the hills.
          haven't towed yet, but the temp gauge hasn't moved from anything but normal
          more tests to come.
          dan
          Dan - Prado 150 GXL - now for sale
            ABR-SIDEWINDER HID Lamps now fitted.
            Here are a few pictures.
              Here is a animated gif of the lamps. I fitted one pencil and one wide beam and did a test tonight.
                Hi Derek
                You are a guru with the photo software, nicely done, I see your fog lights are in the bar as well now, do they fix up the shadowing?
                Regards, Richo.
                  Originally posted by Richoson
                  Hi Derek
                  Regards, Richo.
                  These photos are with the fog lamps switched on. The shadow is worse with them switched off. I will take a photo this weekend if I get a chance.
                    some Lightforce XGTs
                      Hi Guys
                      Where has anyone mounted their driving light switch? There are a few blank switch places on my GXL. Has anyone bought a switch that fits neatly in one of the blank switch places? Where are you picking up the high beam power wire, in the cab or in the engine bay?
                      Thanks for advice in advance.
                      Mark
                      Mark
                      150 Series GXL White T/D auto
                        Originally posted by Snowmann
                        Hi Guys
                        Mark
                        Hi Mark
                        I have IPF's and they have a switch that looks like a small computer mouse, I brought the cable out where the steering column shroud is and mounted the switch on the flat part of the dash with double sided tape besdie the mirror controls. It is quite unobtrusive and only the driver can see it. I picked up the high beam wire from behind the headlight as it is not covered by loom tube there.
                        Regards, Richo.
                          Hi Guys
                          Mark
                          I have an ARB bar without fog lights (don't get much fog here in Central Qld), I fitted HID modded IPF 900xs spots using the IPF wiring loom but rewired it to use the fog light switch instead of the mouse switch and ran it through the high beam circuit. I like the genuine look and the switch from newprotech doesn't fit the new 150 series. You could do the same with other wiring looms or your own wiring loom.
                          Wrocko
                          • #28
                            here are our IPF900XS soon to be upgraded to HID
                            2010 Blue Storm GXL Deisel Auto, HR towbar, uniden UHF, 270/65/17 BFG A/T, Delux ARB bullbar (FITTED), IPF Xtreme Spotties, Safari Snorkel (to come) Sungrabba mats (awesome)
                            • #29
                              The Ironman HID's seem to work very very well, and I am extremely happy with how they look
                              [b][i]Prado GXL - 2" TJM Lift , Roof Rack, ARB Deluxe Bar, Ironman 12000lb Winch, Ironman HIDs, Simoco Radio,Cargo Barrier, dual battery[/i][/b]
                              • #30
                                I am tossing between Narva 225, hella 4000 and lightforce 240. I have an ARB bar fitted. I don't want the lights to protrude beyond the bar in case we bump something which will probably damage the lights. Additionally I am concerned about whether any of these lights may cause excessive shadowing with my arb bar.
                                Can anyone comment on these concerns as to which lights would be best. Comments on quality ,best lights are also welcome but I suspect a lot of this will come down to personal choice.
