RJ45 pass through for UHF radio
  • RJ45 pass through for UHF radio
    RJ45 pass through for remote handheld mic UHF radios.
    $28 posted Australia wide
    Send an email to amtsprado at gmail dot com
    Fits directly into the switch blanks of 150 Prados and other Toyotas with switch blanks measuring 22x33mm.
    Toyota FJ Cruiser 2014 - Onwards (above rear view mirror - check depth for wiring room)
    Toyota Fortuner
    Toyota Hilux 2015 - Onwards
    Toyota Landcruiser 200 Series 2008 Onwards
    Toyota Prado 200 Series 2015 - Onwards
    Toyota Prado 150 Series 2009 - Onwards
    Toyota Prius-V 2012 - Onwards
    Toyota RAV4 2006 to 2011
    Designed not to get pulled out under rough use eg, mic being used by rear passenger or while standing outside the vehicle.
    Comes with flap to keep dirt out. Flap can be removed completely as well if not needed, eg when mounted in a vertical switch blank.
    Needs Ethernet cable to reach the main UHF unit. Recommend cables without a boot over the RJ45 plug for tighter bend radius and to fit through the opening of the main UHF unit.
    amts
    Ninja Poster.
    Sweet. Are these for sale?
      I'm keen also to know where to find some of these.. very handy solution!
        Yes they are for sale. I designed them and got them injected molded after a lot of trial and error.
          Great, how much and how do we purchase them?
            Awesome - I will have one as well
              First post updated with further details.
                They look good. Definitely a lot neater than the hole i cut in the switch blank for mine!!
                I have sent you an email!!
                  Hi AMTS,
                  How secure is the flap? I'm thinking about mounting one of these next to the 12v plug by the handbrake on my 150. The kids sit on the centre console from time to time so hoping the flap may stand up to some rough treatment from shoes.
                  Nova
                    Originally posted by Nova View Post
                    Hi AMTS,
                    Nova
                    Not sure, haven't tested that specific scenario. The flap is quite low profile and locks in via tabs at 3 points. As long as they don't catch the bottom edge where you would normally slip your fingernail in to open the flap, it should be OK (but no guarantees).
                      Email sent, looks better than my current setup.
                        Hi Andrew,
                        Finally got around to fitting mine up and it reminds me, i need to clean the inside of the Prado
                          Hi there
                          do you have pass through in the square type size?
                          suit 2018 model to come through at the switch block near your left knee
                          cheers Craig
                            It’s around 22-23mm square
                            same blanks in the 4wd section on GXL in front of cup holders
                            cheers
                              No, sorry.
