Bull bar questions
  • Bull bar questions
    If I’m going to get a bull bar fitted, such as an ARB Summit bar, will I need to get my suspension done due to the extra weight? Also, can my Roadsafe recovery points be fitted to such a bar?
    The last thing I want is to think I’m up for 3k for a colour coded bar and it ends up nearer 5k because other bits need doing as a result.
    Do people ever run bull bars with zero effective lift I.e. just reset for sag, or will most stick a moderate lift in? I’m more keen on ensuring reliability rather than changing angles and putting components at greater risk of failure. Although I’m not a mad keen bush bashed I wouldn’t mind getting up to the tip at some point.
    Where the summit bar front plate sits around the recovery point (arb though)
    2018 VX Prado
      Summit bar and warn zeon winch on stock shocks.. 2018 vx
      2018 VX Prado
        18 VX summit bar with 2 arb recovery points, on stock suspension, front sag: 3mm, rear: minimum.
        No winch yet, but you do feel 'heavy noise' when braking a bit hard or making sharp turns like U turn.
        2018 Prado 150 VX ARB Summit Bullbar ARB Recovery Points Toyota Towbar Rhino Backbone Pioneer Platform Provent Catch Can Dual Battery Blacksys CH-200 and more to go
          Thanks for those responses. The minimal sag is good as it will at least make it practical to upgrade in parts, albeit with ARB’s somewhat more expensive recovery points. I guess that at least they’re responsible for everything then. Also means I can add th snorkel. Have you raised the breathers or left them stock?
            Mine are stick but will be raised shortly
            2018 VX Prado
              Putting the arb recovery points is a task.. you need to remover the plastic bumper and aluminium bar behind it..once that’s done it’s easy enough although Arb’s instructions leave a lot to be desired particularly in respect to compressing the nursery, where they say to fasten it you need to turn the nut clockwise binds it against the bolt head, the when in fact you need to turn it anticlockwise to force the bolt out to compress the nursert.
              2018 VX Prado
