finally getting around to installing a uhf into my prado. I did see a while back a step by step post with pictutes on how to do this but. Unfortunately cannot seem to find it now. Want to hide the uhf behind the facia in the drivers side footwell and use a rj45 pass through. Appreciate any help on how to do this. Regards keith
Fitting uhf in 150 series 2011
I mounted my unit behind the horizontal panel under the glove box, this is a better location if you are wiring direct to battery. You will need to cut away some foam material to make it sit in. I purchased the Lightforce RJ45 pass through with fits into one of the switch blanks (see link below). Just make sure you get the prado one with the correct light colour.
https://www.ebay.com.au/itm/LIGHTFOR...-1xV:rk:6f:0
Mine is mounted behind the steering column cowl in foot well & RJ in spare switch location on consol. Handset just next to it.2011 GX Blue Storm Auto D4D
2" OME Lift, BFG AT's, Speedy Avalanche Wheels, ARB Bar, Safari Snorkle, Duel Batt Setup, TG150 Guard, TJM Side Steps, Tinted, Spotties, Draws, Rhino Platform, Recovery Points, Tin175 UBP.
