Hi Everyone,
I bought the Toyota genuine aero roof rack bars a while back (part number PZQ3060200) assembled the whole thing, used it a few times then took it off and haven’t used it since.
Recently I need to use the roof bars again but have misplaced the installation instruction as well as the supplied Allen key to install the bars. Luckily I still have the security keys to remove the end caps.
I’ve read that Rhinorack is the oem for these bars albeit slight different lock mechanism.
Would someone out there be kind enough to post a pdf or photo of the Toyota installation manual for the roof bars so that I can install them correctly again?
Also can someone also confirm that this Rhinorack Allen key is what I also need to install the cross bars?
https://www.rhinorack.com/en-au/prod...sxb_torkey-sxb
Thank you in advance.
