Testing new dual battery system
  • Testing new dual battery system
    No doubt some will get a giggle out of this one, but here goes ... !
    I have just finished installing a dual battery system, rear power outlets and Camper Anderson plug. However I don't actually have my auxiliary battery yet as I'll be getting it in a few weeks when I go to Brisbane. For the sake of going through the testing regime for the system, could I put the only other 12v battery I have from my ride-on mower(!) in the aux battery tray but only to check that the system is working OK, then remove it. The bit I'm mainly concerned about is where the engine is started to check voltages in both batteries. Is there a risk of frying the lawn mower battery with the alternator's output (or worse; smoke, sparks or fire!).
    The installation instructions were fairly straight forward so I'm hoping it should all be OK, but if there are any glitches I'd prefer to find out now before I do the big trip to the city as I won't have time to stuff around with it down there.
    150GXL D4D auto with a few xtras; & a Lifestyle Podium [i]i[/i] Camper trailer
    Re: Testing new dual battery system
    As long as it is a 12V battery and your vehicle does not want to crank off it then it should be OK. Remember if you are going to travel anywhere that you tie the small battery down so it does not walk anywhere.
    Regards
    Crisp Image
    GX 150 with 3rd row seats, Milford Cargo Barrier, factory roof racks,Tekoncha P3 & a duel battery system..
      Just use a multi meter on the terminals of your aux battery. After you start your car, soon after you should see a light or hear the relay click over and you should have charging voltage at the aux terminals. If this is ok hook the aux terminals up to the wires running to the rear and check the voltage at the back with the multi meter.
      [color=#4000FF]2010 GXL, ARB BAR, GOODYEAR MTR'S ON STEEL RIMS, CUSTOM REAR DRAWERS, DUAL BATTERIES, CARGO BARRIER, GME UHF, RHINO ROOF RACK, ROCK SLIDERS, AIRTEC SNORKEL, DUAL DROP FRIDGE SLIDES[/color]
