How do I remove the centre console between the seats on a 150 kakadu
  • How do I remove the centre console between the seats on a 150 kakadu
    Guys I need help on how to remove the centre console between the front seats. I've searched but can't find anything. I want to change to lighter over to run of the aux battery.
    Would really appreciate some guidance or tips on how to do this
    2012 Kakadu
    Have a look at this thread....
    http://www.pradopoint.com/showthread...hlight=console
    [/CENTER]
      Thank you for that, very helpful.
      That's a start though I'm hoping someone whose taken the whole console out might be able to share the full process...
      2012 Kakadu
        Mate.... The following link will show u how to remove your centre console.....have a look here:
        http://www.pradopoint.com/showthread.php?18503-What-aftermarked-radios-will-fit-the-top-slot-of-the-150&p=311563&viewfull=1#post311563
        rob_macca67
          I remember someone installed their UHF under the console near the gear stick but I have been able to find the thread again. I am pretty sure that it had some good photos showing it pulled apart.
          [/CENTER]
            Bump....
            Cant find the thread as per above.... been looking for a while now and I still cant find it...
            [SIZE=1]2013 D4D Auto Crystal Pearl "Altitude" - Caloffroad Bilstein 3 inch lift, SPC UCA's, diff drop & sway bar ext. FJ Rims-ET15 285/70R17 Cooper ST Maxx. ARB deluxe colour coded bar. Lightforce 240 XGT's. Modified X9 winch, 6hp motor & 30m 10mm rope. Dual Batteries, Redarc-SBI212, Mk3 diode & custom wiring. Water watch. ARB compressor. Twine underbonnet shower. Scangauge II. Custom rear draws. TG150. Tectyle rust protection. GME 3600 UHF, AE4705 antenna. PWR ATF cooler. Genuine tow bar.[/SIZE]
              I'm not sure if this is the thread you are referring to but it does show how to remove the console bits :-
              http://www.pradopoint.com/showthread...ghlight=brains
                Bingo! That was it. Thanks heaps for that, looks like a waslooking in all the wrong places. Cheers Chris
                  That's OK, I knew where it was because I asked Brains to do it.
