gday guys noticed the other day that there is condensation inside the drivers side headlight, i removed the bulbs on that side to try and get it dried out but no luck as yet, any other places i should check for water ingress, many thanks for the continued support...
condensation in headlight
G'day brownie,
It could have a slow leak around the seem?
Usually water can get in a light when you pressure wash it. Particularly from the back, where the globes go in.
Need to dry it out properly, be carefull next wash?
If it keeps getting in normal driving, likely you need to pull it out & find the leak.
Did you blast it recently?
How's the suspension?
mate suspension is GREAT i am taking some photos and put up stats, i normally dont pressure wash under bonnet but may have got a bit over zealouse with the garden hose, will try and dry it tomorrow again....2010 Blue Storm GXL Deisel Auto, HR towbar, uniden UHF, 270/65/17 BFG A/T, Delux ARB bullbar (FITTED), IPF Xtreme Spotties, Safari Snorkel (to come) Sungrabba mats (awesome)
Hello all,
I had water in my RHS headlight and I had not washed inside the bonnet at all, the complete headlight assembly was replaced under warranty at 2.5 years after the dealer could not dry it out using the headlight globe heat. As if high beam (55 plus 35 watts) was ever going to dry it without letting the vapour out. Visit the dealer and try him on.
regards
Ross
