SmartBar and Roadsafe recovery points
    The winch compatible Smartbar is different to the SB that is not winch compatible. Mine is winch compatible and the only way I could fit recovery points would be to space out the top mount as the winch cradle is bolted in to the lower mount hole, but not the top mount.
    Cheers..........Wayne
      A little old thread I know, but I installed my Roadsafe recovery points on the weekend.
      I have a Facelift 150, MY14 with the black Smartbar (with winch cradle I believe!)- http://s7.postimg.org/xuataip8r/IMG_9245_2.jpg
      As Wayne said above, the top mount is spaced away from the chassis rail because of the winch cradle on the bottom hole mounts. A couple of washers in between the top hole, helped reduce the gap.
      Before (with one bolt in the top to check it)- http://s21.postimg.org/rbac2d86v/IMG_9415.jpg
      After - http://s14.postimg.org/5xw13pw1d/IMG_9420.jpg
      It may help someone else, as there were no instructions for Smartbars. Seems very similar to the ARB bullbar installs.
      - ghandi
      Ghandi
      -Safari snorkel
        - ghandi
        I had the same issue, I used a large 3mm thick washer. seems to work ok. your bar looks close to the car, is there chance that you can snap a pic of the 3 or 4 bolts that mount the bar/winch frame to the chassis mount? I would like to make sure I'm using the correct holes
          Gday leethal, sorry about the delay. Been busy and without the car.
          Im not sure exactly which ones your after, but taken a photo of the attachment points to the chassis rail
          http://i1308.photobucket.com/albums/...psll3xcfeu.jpg
          http://i1308.photobucket.com/albums/...pslmmdnoap.jpg
          Let me know if you need some more detail/pics
          - ghandi
          -Safari snorkel
