What's the best way to remove the d4dturbo sticker on the rear quarter without damaging the paint?
Removing side sticker on prado rear quarter
Use a hair dryer, soften it up, peel it off and clean residue with Eucalyptus oil.
Be aware that people who have done this on 90s or 120s find the sticker leaves a 'stain' in the paint. Not sure if the 150 will be the same. Have a look in the 90 and 120 section or Google search.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Both my stickers seemed to get dirt under them very quickly, I first noticed it first wash! Peeled them off after the second wash, when the dirt seemed to get worse. All I did was park it out in the sun, once hot just peeled them off with my fingernail. I have peeled sign writing off vehicles before though (pre sale prep for one of our clients) and it does take a bit of a knack and some luck to not leave glue everywhere. If you can't get it hot in the sun, use a hair dryer to heat the panel, not the sticker. Where the heat is is where the glue will release, so you want it to release from the panel. If you heat the sticker the majority of the glue will stay on the panel.
Once off I completed the three part polish process to the entire rear guard and you would never know they were there. Depending on how long it has been there will depend on how hard it will be to remove without a trace. I have seen bad staining from some Toyota stickers though, my neighbours 100 has very bad paint stain from the sticker glue. Was planning to replace them, but now I prefer the clean look.Last edited by AussieAndy; 04-01-2015, 03:26 PM.[LEFT]Silver 150 Facelift
Thanks for the comments, most of them anyway! The sticker was put on last week at the panel shop after a little repair to the rear quarter. So should come off ok. Just getting it to start on the edge without damaging the paint seems like the worst bit. The buggers stuck it on an angle opposite to what it should be. It's already Been back for a redo so don't trust taking it back so have ordered another sticker and will do it myself next week when I get back home. Some good tips for me to follow thanks AJ120 and AussieAndy.
Sticker was ordered from local toyota dealer for $22. Before I flew back to work I tried gently on edge of sticker to peel it but seemed to be on good. Thought as paint was only 2 days old Maybe a little soft? I should really take it back to crash repair joint and get them to do it, but they will think I am just mad.
The side plastic piece along the windscreen has disappeared. Went back to panel shop today as they had it removed and the buggers broke the clips originally and just glue it back. I think a trip along the freeway and its blown off. Anyway they have ordered a new strip and clips. Showed the guy the sticker that was put on as its out of wack and agreed. The sticker comes on a template so you line it up to the tail light edge and put it on. Just so easy. Just a lazy sod stuck it on without care! Anyway the Panel shop will redo the sticker now so might as let them and if they stuff anything they can fix it.
