After heavy rain I have water on the inside of the windscreen which looks like heavy condensation . I've removed the roofrack and re fitted the OEM roof rails as I had water under the drivers seat and in the rear footwell and found evidence of water coming down the centre pillar where the seatbelt is mounted . The interior has been dried out but still getting condensation on the inside of the windscreen but the carpets appear to be dry . Any ideas please ? Cheers Ross
Wetness on inside of windscreen
Did you smother the roof rail bolts with silicon when you put them back in? Probably most likely point of entry. Depending on how much water you drove through it might be worth checking floor plugs are in position too.150 D4D GX with big tyres, TPMS, Tracklander, GME, Safari breathing straw & super soft squishy custom rear springs.
