Does anyone know how much the standard roof rails can hold? Thinking of bolting my aluminium roof rack directly to the rails with U bolts?
Standard roof rails
The north south rails are rated to 80kg.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Well that is correct for the 2 factory supplied normal rails. If you go down the path of heavy duty 3 rail set I think they hold up to 100 kg or bit over. So direct attached would be more as you do not have the weight of the rails in that equation.Originally posted by mjrandom View PostThe north south rails are rated to 80kg.D4D. How long will it last?
