Aftermarket front recovery points for 150 Series
  • Has anyone a picture of Outback Ideas recovery points fitted to a 150 with an ARB bar ?
    Whats involved in fitting them ? Santa's getting me a set (i have to go pick them up for him as hes very busy with late night shopping)
    [size=1]2011 GXL D4D Auto | ARB Deluxe winch bar | Bilstein/Ridepro platinum lift | MT ATZ P3's | Dick Cepek Torque rims | Airtec snorkel | Lightforce Genesis 55w HID | GME UHF | 55w HID high beam | Rhino Rack bars & Cage | ISI extreme rack | Dual Optima Batteries | Milford MXV-70 cargo barrier | ARB onboard air | Prodigy P3 | Drawers & Black widow fridge slide | Waeco CF-50 | Kaymar rear bracket and LED light | EscapeGear seat covers | Sandgrabbas and more...[/size]
    • I've got a set, but I'm hanging out for the new ARB points, as they look great.
      2011 150series GXL
      • Hmmmm, im in no rush.... i have 3 trips planned for next year, first one May so if theres better recovery points im all ears.
        Will do a search for these ARB points, you got anything on them Wooley ?
        • Originally posted by alternative View Post
          I'll post up some pictures tomorrow
            I was having a look at a set of hilux ones the other day, I was told the prado ones will be similar in design/construction, but obviously specifically to fit a prado.
            http://www.arb.com.au/media/press/De...veryPoints.pdf
            the pictures aren't great but they're the only ones I can find.
            2011 150series GXL
              Installed on my Sahara bar... more pics and installation tips on my buildup page 25...
              Hope this helps.
              • Originally posted by wooley View Post
                They look the goods...
                • Thanks guys Will call ARB tomorrow and see what the ETA is on their points. If they are a bit off or i get a vague answer i'll grab the outback ideas. They look good William, great write up too.
                  • Hi all
                    I read through all the posts on this topic and couldn't find a more recent reply to Ages question about fitting the OI recovery points to a TJM bar (other than mention of them being drilled to suit both ARB and TJM bars). Has anyone fitted these to a TJM T13 steel bar, and if so, any pics?
                    tks
                    Westy
                    Originally posted by RobA View Post
                    Just had my fitout complete which I will post later. We have found that with the steel bar that the standard Outback Ideas recovery points cannot be fitted as the protection plates from the bull bar mount to the same points. So the OI guys are working on a modified one to suit as we speak
                    Regards
                    Rob
                    • Hi guys,
                      For the past 6 weeks I have been waiting for the delivery of my front recovery points that I ordered from my UV4X4 shop here in Ipswich Qld.
                      Today they called me to notify me that they could not supply as their supplier was not manufacturing these anymore as he was "apparently" going broke. The guys at the UV4X4 shop mentioned that their supplier was Outback Ideas. They also mentioned that they have been chasing him for weeks about the supply of the recovery points, and he finally came back and said he was not supplying.
                      UV4X4 are also agents for ARB and they also do not have a rated front recovery point for the 150 series.
                      So my question is, Who the hell makes front recovery points for the 150 and where can I get some from???
                      Im told that the ARB ones are some time away.
                      Also what are the guys with 150's using that are going to the GTG 2012? As from what I'm lead to believe you cant attend without rated recovery points!
                      Jeff
                      [SIZE=3]Jeff[/SIZE]
                      • Originally posted by Jeffers View Post
                        Hi guys,
                        Jeff
                        I've got a brand new set of 150 series outback ideas points sitting here which are surplus to requirements if you want...
                        Shoot me a PM and we can talk price.
                        2011 150series GXL
                        • Jeff give ARB Coopers Plains a call they had the 150 Outback Ideas points in stock.
                          Richo.
                          • Originally posted by Richoson View Post
                            Richo.
                            Thanks Richo,
                            Wooley is helping me out
                            Jeff
                            [SIZE=3]Jeff[/SIZE]
                            • Just wondering if anyone has used these front recovery points by Everything 4x4. Apparently they are australian load tested and stamped with a WLL of 5t. They look a lot like the OI points.
                              I have sent the supplier an email to see if they work with an ARB bar fitted.
                              • RWO,
                                I was just looking at the same thing just now, looks promising as seem to be rate???
                                But the recovery point is rated in itself, but what about how/when it is attached to the vehicle?
                                http://www.ebay.com.au/itm/TOYOTA-PR...ht_4317wt_1163
                                Bernie
