Was under the 4b looking at things as you do when i noticed something odd. Around some of the welds the black paint has chipped off and you can see what looks like rust. Got a bit panicy cause the more i looked around the more i noticed these little chips of paint missing and what appears to be surface rust.
Took it down to the dealer and got them to put it up on the hoist for a closer inspection and to show them. They tell me it's not rust but the protective coating that the chassis is dipped in prior to painting (happens to be yellow and looks similar to rust colour) and it's not uncommon for there to be chips of paint off. They then showed me the same thing on a new hilux tray back minus the tray. Yes you could see these little imperfections on it as well. I told them that i still think the paint shouldn't off chipped off allready.
So the question is is this normal and okay or abbynormal and needs working on.
Could some 150 owners check their chassis and let me know if theirs is the same.
Here is a pic of one weld on the rear chassis rail back pass side behind axle. You can clearly see the orange ( rust / protective coating) along the weld edges.
Thanks Ant
Thanks Ant
