150 Brake pad life
  • 150 Brake pad life
    I was surprised to find that my rear pads needed replacing at 50k and fronts were about half worn . I've always found on several cars that I've owned that the fronts go first and the rears go on and on . Anyone else found this ?
    Ross
    I understand that the rear pads are smaller than the front ones. There is also a proportional valve in the rear that is attached to the diff housing that picks up if there is a load in the rear of the vehicle or if it is towing and therefore applying more braking force to the rear.
    If you don't carry heavy loads or tow lots I would have them checked for operation. My fronts are apparently 1mm better off than my front ones. (But I don't trust the service agent to get the measurement correct). Get a second opinion from someone you can trust.
    Regards
    Crisp Image
    GX 150 with 3rd row seats, Milford Cargo Barrier, factory roof racks,Tekoncha P3 & a duel battery system..
      http://www.pradopoint.com/showthread...Brake-Pad-Life May help you with your answer.....Cheers Steve
