Originally posted by mat-with-one-t
View Post
Transmission cooler fitment
My mechanic mentioned during a service about 2 years ago that my transmission fluid was bad and needed replacing. And when I started towing a caravan I read on a Prado group about the scan tool and how to check your ATF temperature. I saw that the temp was quite high when towing in Drive. I want my Prado to last and decided to get the ATF cooler which definitely brought the temp down a lot. Initially it was higher than the engine temp, but now it never gets close to it. So very happy now and can recommend the Koan transmission cooler. Just my experience for what it's worth
From one of Australia's well known Trans specialists.Originally posted by gunda View Post
Reduced from what, Piggy? What's the reference temperature? I'd have said that on flat terrain when not towing and in temperate conditions, 88° was what the ATF eventually stabilises at. What's the source for those quotes?
We have also had oil/ trans fluid samples taken from various fleet vehicles including the Prados and sent off to the lab for analysis, and oil life is pretty well spot on to what he says. Yes, you can leave the oil in longer but is it good for the components? Not really.
Bottom line is: Oil breaks down quicker when it's been run at higher transmission temperatures. EG, Someone who gets the Trans oil temp light comes on a couple times, Should be looking to replace that Oil asap. If the oil has been in the car for ages, then damage will be done quicker.
Piggy is correct with the trans temps to mileage ratios.
Toyota have always said “sealed for life” since the asin 750f in the 120. That is complete rubbish. It’s more like a “sealed until warranty runs out”.
In the owners manual it states that you should change it at 80k if using under extreme conditions. Most Toyota techs will tell you “nah, sealed for life” if you ask for a flush, even at 150k.
Optimum temperature is 80-90 degrees for trans temp. As piggy showed, if kept at 90 degrees, you will safely run it for 80k. Mine usually sits 90-100 when towing with times up to 110-120 on soft sand. Therefore I choose to service it every 40k.
Most trans places will sugggest about 50k services regardless. I feel they are the ones who have an interest in looking after the trans. Toyota have an interest in giving us the cheapest possible service price and a trouble free warranty period.
I'm considering getting a transmission cooler fitted because I tow a 2.2t van with my MY21 Kak, sometimes in hilly country. On a few occasions I have seen elevated temps on my Scangauge.
I am not going to do it myself. I just got a quote of nearly $1400 from a local 4WD specialist, plus a bit over $800 for a flush. That seemed expensive to me. The Kaon kit is $440. What have others paid?
Can anyone recommend someone suitable in the ACT or surrounds?
Does that service come with a bag of diamonds? The quote for the flush is more than double what evenToyota will charge Try towing in 4th. With my 2016 towing about 1300kg camper at 100 kph in drive 125 deg will come up very quickly. A change down to 4th will see the temp fall to the 90s within a few minutes.
I'm going to ask around at a few other workshops. I have to admit that I was a bit taken aback by both quotes, although less so by the flush, as I have been charged not all that much less than that for transission flushes on our other (European) vehicles. I was really taken aback by the cooler quote. Part of that may be which cooler is fitted. Looking online I see that brands other than Kaon are more expensive, and the quote seemed to be for one of those other brands. Their rough quote for a GVM upgrade on a Kakadu was really eye-watering.
My MY21 locks in 5th (and 6th in the right conditions) quite readily and that's not the issue. I know that from the scangauge. The occasions when I get elevated transmission temps are on steep, winding climbs when I have to slow right down for sharp cornerr, or on rough dirt patches, and then accelerate again. Typically I'm in 3rd or even second and doing my best not to work the transmission and transfer case too much, but there are limits to my ability to manage the temp by sticking in one low gear and trying to keep an even throttle.
I put a Kaon/Davies Craig - based kit in my previous Prado GX and plan to do it again with my new 2023 GXL. It's a bit messy to do it yourself but saves a small fortune.
A week or two later I then had the transmission serviced and ATF replaced at a reputable 4X4 auto transmission centre ($525).
