So I recently stripped the chain gear in the transfer case on a weekend out, limped the car back home and managed to source a "zero k's" transfer case from a stat w/o. Once I installed the new unit, the centre diff light flashes like an indicator and the transfer case beeps with every flash. The centre diff is permanently engaged, and pushing the diff lock button does nothing. Furthermore, turning the the h4 to l4 also does nothing. I have removed and re installed the transfer case, checked all the vacuum hoses for kinks, checked the wiring harness into the case, no pulled wires or dodgy connections. I've lifted all 4 wheels off the ground to get rid of any wind up, yet it won't correct itself. I have even left the car disconnected from the battery overnight to reset the ecu, but it still won't disengage.
Any ideas???
Any ideas???
