4th and 5th gear problems
  • 4th and 5th gear problems
    G'day all,
    on the weekend gone by i had some issues with my gearbox, car is 2014 GXL auto.
    i was cruising on the freeway at 110, no problems, everything was running fine! approx for 1 hour.
    after i slowed down entering a town - navigating through traffic i went to speed up to 110 again and the gear box refused to shift into 5th. staying only in 4th.
    there was no excessive external forces ie... headwinds or uphill or towing.
    trying to manually change the gears did nothing either, with use of tip-tronic.
    after i pulled over and selected park, i tried again. no change
    i pulled over once again, turned off the vehicle waited for 20 seconds, and bingo everything back to normal.
    it only 'locks' into 4th after 'extended' use of 5th.
    2 days prior to my small trip i had the vehicle serviced for its 30 000. but they claim they did not touch my transmission.
    any help would be greatly appreciated.
    car is remapped however it was done 10 000 kms ago with no dramas whatsoever.
    Hey Jordan, did you happen to get this issue sorted mate? im having the same issue in my 13 model now
      Think there was another thread on this topic. Seemed The only common detail was we all had reflashed ecus and EGR turned off.
      Mine tends to hang in 4 if the car is slowly gaining speed downhill.
        Hey Jordan. Did you end up getting this issue rectified? My 2014 GXL Prado is now doing the exact same thing! So far my mechanic has not been able to find a solution. Any help would be much appreciated. Thanks.
          my car has started doing this. 2010 has been remapped also
            Remap and EGR turned off seems the common link. Clearly the ecu’s get confused, but I can live with it.
            Not going back to stock power.
