Auto transmission fill test tube fail?
  • Auto transmission fill test tube fail?
    Anyone had the transmission fill test tube break off due to corrugations? I had a cooler leak and removed it and then checked to see how much oil was in pan but the test hole flowed oil out. I don’t think it’s overfull, maybe the fill tube has broken off due to corrugations on the Oodnadatta track?
    Never heard of it. I’ve done a lot of corroguations but never seen that. Not saying it can’t happen.
    You would need to remove the pan to check ideally unless you try undoing it and wait until the oil drains and then slide a wire in to check (carefully)
    Id probably book it in for a filter change and flush then they can check it while the pan is out.
